what is realistic?
I want 400 hp at least, and as I am reading various topics here I will also need to upgrade my transmission (its an auto) and rear end...
So someone please enlighten me....
With a 93, you can get the 400hp (crank) or just about that much, with ported heads, RR, LT4 Hotcam, and exhaust. Although the hotcam may not be quite ideal for an automatic, depending on driving preferences. It makes its power at higher rpms, and you might want something more low/midrange. I would figure that this should still make good mileage, with tuning.
You wont need the rear modified to handle the power, unless you drag race. Then it becomes necessary to change to Dana 44, otherwise you will eventually blow that rear. Maybe not the first day, maybe it'll last 1000 passes, but it will go sooner or later, especially on slicks=boom.
Tranny will definitely need a cooler installed, thats all it requires, but for precaution you would be best off having one professionally rebuilt with upgraded soft and hard parts if you want it to last 20K+ (some round number, i'm just guessin). Not to say it WILL blow after the engine stuff is done, but theres a damn good chance.
