ARAP in '86
Old Nov 20, 2003 | 07:58 PM
ben73's Avatar
ben73
Default ARAP in '86
It seems lots of guys use the ARAP bin as a starting point, even with older cars. For example, if I was to burn the ARAP bin onto an '86 eprom, would it work ok?? I have read here that I would also need to do the following:
Just unplug the 9th injector.
And make sure you change the "Crank Fuel Pulse Width Multiplier vs. Ref Pulses (1-16)" table or you will have extended cranking.
I changed 1-8 from 0.000 to 0.500 and it fires right up.
Is that all that is needed?
Thanks.
Ben.
Old Nov 21, 2003 | 12:22 AM
scorp508's Avatar
scorp508
Default Re: ARAP in '86 (ben73)
It'll work. :yesnod:
Old Nov 26, 2003 | 10:19 AM
Br1dgeman's Avatar
Br1dgeman
:iagree: It will work, however, if you have iron heads your spak tables may be a little too aggressive. Watch for spark knock and enjoy.
To ARAP in '86
