engine bay shot with juice
Old Nov 23, 2003 | 01:50 AM
1996man's Avatar
1996man
Default engine bay shot with juice
does anyone have an engine bay shot of different nitrous etups on assorted LT1s? i am curious how hidden you can have a system or how obvious its always going to be
Old Nov 28, 2003 | 09:45 AM
red-y's Avatar
red-y
Default Re: engine bay shot with juice (1996man)
If I had a photo of it hidden you could not see it. :skep:
The systems that I have "not seen" have been dry and the lines are under and inside the intake plenum. Everything else is hidden wherever (wheel wells, under car, tanks in the spare tire compartment - dangerous etc.). Not much room in the Corvette. Camero's have a better chance of hidding.
Once you spray it is not a secret anyway. :thumbs:
[Modified by red-y, 8:46 AM 11/28/2003]
Old Nov 30, 2003 | 04:37 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
I have one inconspicuous setup and one obvoious setup. If you know nitrous you would see the "hidden" one, but a general glance, will leave it unnoticed except for the bottle in the back.
Old Dec 1, 2003 | 09:41 AM
1996man's Avatar
1996man
Default Re: engine bay shot with juice (Vette92)
great! thanks for the info? anymore?
Old Dec 30, 2003 | 05:36 PM
fiberglasscoffin's Avatar
fiberglasscoffin
nothing to hide here
[Modified by fiberglasscoffin, 4:36 PM 12/30/2003]
Old Dec 30, 2003 | 10:34 PM
neat's Avatar
neat
Default Re: engine bay shot with juice (fiberglasscoffin)
A west kit is hard to hide. The best way would be to use a shark nozzle plumbed into the bottom of the intake tract. Then use black wire loom to cover the lines.
During an N20 blast, the exhaust has a faint (yet distinct) slightly different odor. Anyone arouund racing for any length of time will be able to smell it. You might be able to circumvent that with medical grade N20 though, as it is the sulfur that smells.
Old Dec 31, 2003 | 07:43 PM
Dan Parker '96's Avatar
Dan Parker '96
Another "obvious" TNT setup..
and bottles (minus the bottle blanket)
[Modified by Dan Parker '96, 6:54 PM 12/31/2003]
Old Jan 1, 2004 | 09:41 PM
zelement's Avatar
zelement
Default Re: engine bay shot with juice (Dan Parker '96)
Here's mine.
NX gemini twin with supercharger
without supercharger
the solenoids are inside the air pump eliminator brackets
and my old nos plate with dual nozzle kit on TPI
Old Jan 2, 2004 | 12:51 PM
AKS Racing's Avatar
AKS Racing
Default Re: engine bay shot with juice (zelement)
Zelement,
Did you powdercoat the supercharger (Vortech, I think), or is that paint.
I have a D2R that I am considering "breaking down" and powdercoating black. I dislike polished aluminum and chrome. I like the flat black look. Others have said that they have ruined a sc case by powdercoating, but that may just be talk.
Thanks,
Aaron
Old Jan 2, 2004 | 10:48 PM
zelement's Avatar
zelement
Default Re: engine bay shot with juice (AKS Racing)
Aaron,
The charger is painted. I didn't do it, the shop that put everthing together painted it.
I saw him do it, he had to take it apart and paint it then put it back together.
Paul
[Modified by zelement, 9:55 PM 1/2/2004]
Old Jan 7, 2004 | 02:23 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
This in on an LT1 Impala
http://www.azsupersport.com/hiddennitrous.asp
There's a forum member with three tanks down where the spare tire carrier is. :thumbs:
Small bottles
Holley SneakyPete
on an F-body
http://www.gafba.com/articles/article.asp?tid=4
This place sells them
http://www.raceworx.com/hidden_systems.html
Hidden Bottles:
Inside rear quarter panels
Spare tire wells
Inside back seat cushioning
Inside glove box
Under dash
In fake power brake booster
Inside an OIL PAN (NASCAR trick, busted)
In subwoofer boxes
In black duffel bag behind seat (CompuCar Street heat kit, 100 hp max)
Hidden solenoids:
Under dash
In fake brake booster
In lifter valley
Inside air cleaner (carbed application)
Inside valve covers
Behind block, fogged black w/spray paint.
Hidden nitrous injection systems:
Directly into heads (MAN are you BRAVE)
Plumbed with fogger nozzles into BOTTOM of intake manifold (NOS does this on a custom basis, looks sweet.)
Dry kits plumbed before MAF sensor, in fender well pipe (inside fender plumbing)
Plate kits (carb apps) covered by drop base air cleaner
Inside air cleaner entirely, sitting on carb (NOS brand Top Shot kit)
Hidden activation methods:
Horn button
Throttle switch (under dash is best)
Or a hidden momentary switch in ashtray or on a coil cord, stuff into ashtray when not in use.
[Modified by BrianCunningham, 2:24 AM 1/7/2004]
Old Jan 14, 2004 | 03:48 PM
1996man's Avatar
1996man
Default Re: engine bay shot with juice (BrianCunningham)
WOW! thanks for all the resonses! For those of you with the NOS lines laying on top of the intake manifold, would it be possible to run those lines next to the fuel rails so they can all be under the fuel rail covers?
Old Jan 15, 2004 | 11:18 AM
Dan Parker '96
I'm sure it's possible with some creative plumbing. I personally don't like the fuel rail covers. I like to see all of the intake manifold and the rest of the "stuff".
Old Jan 20, 2004 | 09:28 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Old Jan 20, 2004 | 09:52 PM
StealDads67's Avatar
StealDads67
Default Re: engine bay shot with juice (fsr402)
The TNT kits looks totally superfluous with all those lines and 45* nozzles out the top of the plate like that....
Almost as superfluous as me using the word superfluous instead of just saying, There to much crap on top of the motor with the TNT.. It seems pointless to me, I would like to have it on the side so Its not in my way all the time.
Just my thoughts. (Im bored right now)
Old Feb 19, 2004 | 11:08 PM
1996man's Avatar
1996man
Default Re: engine bay shot with juice (StealDads67)
are all these kits "dry: kits since they dont spray it in with the fuel? is that a wet kit? please explain the difference and post pics of both is possible
Old Feb 21, 2004 | 03:40 AM
zelement's Avatar
zelement
Non of the pictures posted here are dry kits. The only dry kit pictured is the sneaky pete system.
If you look at the picture where the nozzles are drilled into the intake.
The BLUE fitting = nitrous
The RED fitting = fuel
Old Feb 21, 2004 | 10:35 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
St. Jude Donor '06-'07
i have been debating this for some time wouldnt a nos plate miss cylinder 1&2.I have been thinking of the nozzle system.what doy you think the l98 isa little harder to plumb for nos. most systems are dry not wet and a wet sytem is the way i want to go.Not trying to hijact but just curious about what you guy with the plate have seen,
To engine bay shot with juice
