bad mileage question
Old Nov 24, 2003 | 09:29 AM
FNG's Avatar
FNG
Default bad mileage question
hi guys. just got through going through the fuel system on my 85. new from pump to injecters. new filter, fpr, injecters, throttle body. everything. was cruising down the street and mileage went from 16 to 11. from the archives ive read , should be the coolant sensor, or maybe the ecm. 02 senser is new.
so my question i guess, is that the way the coolant senor goes out, just all of a sudden?? would the ecm go out the same way?? the car runs strong, just gets really crappy mileage all of a sudden. thanks guys, ill get this thing right one way or the other with a little help from the forum :D regards, fng
Old Nov 24, 2003 | 02:14 PM
George Dickel's Avatar
George Dickel
Default Re: bad mileage question (FNG)
Figure your mileage the old way before computers. Check actual gas mileage by the odometer and amount of gas to fill the tank. Could be the computer has messed up. Not financially sound to start changing sensors and such if the computer is broke. If the mileage agrees with the computer then start changing sensors.
Old Nov 24, 2003 | 07:06 PM
greg84's Avatar
greg84
hi,any engine codes or check engine light on your dash? greg84 :cool:
Old Nov 24, 2003 | 07:24 PM
Davidsvette85's Avatar
Davidsvette85
I hope what I'm about to tell you is not your problem. My 85 three years ago was getting 18 in the city and as I added new sensors and things on the car and a year or two went by I was getting 14 if I was lucky. Couldn't figure it out at all. Then I started having some more problems so I finially threw my hands up drove it to a shop and told them to pull out the motor and completely overhaul it. And I told them I wanted to know everything they found bad. Well the first thing they called me on was I had 8 teeth missing from my cam timing gear, they were in the pan. The car still felt good and ran good but it had started overheating that was why I took it in. But the timing was off 2 degrees one time out of three times I checked it and the shop told me it could of had the right timing at idle but it may have been changing too much when I was driving it. If you have never changed the timing gears or no one has that you know of the cam gear has aluminum teeth on it. Mine is doing really good now and is getting 18.6 in the city. Check your timing over and over at different times and see if it stays the same.
Old Nov 24, 2003 | 09:00 PM
FNG's Avatar
FNG
Default Re: bad mileage question (Davidsvette85)
greg........no no codes and car runs great
davevette......no overheating, timing is rock solid.
thanks for the input. got a senser today, 12 bux my cost. will try it and see what happens. thanks again, regards, fng
Old Nov 24, 2003 | 09:12 PM
severe-1's Avatar
severe-1
If I make alot of stops (bank, store, lunch etc..) my gas mileage falls way off.
Are you making alot of short trips lately?
Old Nov 25, 2003 | 07:06 PM
greg84's Avatar
greg84
is your tcc working the way it should?this summer when doing highway driving i was lucky getting 16mpg and it was throwing me a vss code,after troubleshooting the code i found that the feed wire from the computer to the tcc soldnoid was broken.once i repaired the wire the mpg jumped up to 24-26 mpg.good luck greg84 :cool:
Old Nov 25, 2003 | 08:58 PM
FNG's Avatar
FNG
Default Re: bad mileage question (greg84)
hey greg..........whats a tcc?? sorry to sound stupid, have no clue what it is :jester help?? thanks, regards, fng
To bad mileage question
