help with MSD
Old Nov 24, 2003 | 11:02 AM
comp94's Avatar
comp94
Default help with MSD
i recently purchased an MSD 6AL ignition box and i was wondering if there was any way to test to see if it was working properly
Old Nov 24, 2003 | 11:21 AM
vvv90's Avatar
vvv90
Default Re: help with MSD (comp94)
Don't know, short of hooking it up and seeing if the car runs....shouldn't take too long.
Sorry I wasn't much help :leaving:
Old Nov 24, 2003 | 11:33 AM
bogus's Avatar
bogus
I am assuming this is for an LT1?
I would not install it... the Opti's high voltage side does not seem to respond very well... kinda burns them out too fast.
Old Nov 24, 2003 | 11:34 AM
Z-PDX's Avatar
Z-PDX
Default Re: help with MSD (bogus)
Presenting the MSD ignition tester...
http://www.msdignition.com/2000_12.htm
Old Nov 24, 2003 | 11:51 AM
ANTI VENOM's Avatar
ANTI VENOM
Bogus
Sorry, but I think that is "bogus". I am using one and have had no problems, but I haven't been using it that long. My friend has had one on his stock opti for over 50k and it is still working fine. Also, I didn't know that the opti had a "high voltage side"? The ignition coil does though. Just my experience!
Old Nov 24, 2003 | 08:17 PM
dizwiz24's Avatar
dizwiz24
Default Re: help with MSD (ANTI VENOM)
For you who have had good luck with MSD, you're lucky.
I had 3 MSD Digital 6 Plus units fail. Had to get the car towed once(Didnt know why my car died, the MSD was a week old). The second time it left me broken down on a busy road at the bottom of a blind hill AT night...And the third time i bypassed it, and the next day took it straight back to the store.
MSD will tell you a unit is easily bypassable and should never leave you stranded. Its just the places it might leave you stranded (construction area, no berm, rush hour traffic in an urban area) are not very convenient.
Im lucky my car wasnt destroyed.
Ever wonder why road racers run 2 MSD boxes with a toggle switch, with all their concern about every ounce of weight..... MSD = Might Suddenly Die.
I also had a brand new MSD 8.5mm wire spark arc against my water pump housing. I had to wrap the area it arc'd in electrical tape.
All that said, I have had heard the MSD 6AL boxes are more reliable on our cars and I had a 1994-vintage MSD 6 box on my 1972 Pontiac Lemans 400
that is still working to this day...
Just be careful out there.
Old Nov 25, 2003 | 11:54 AM
comp94's Avatar
comp94
Default Re: help with MSD (dizwiz24)
thanks for the input guys
To help with MSD
