Do 17-11"s help at Drags?
Old Nov 25, 2003 | 04:11 PM
sothpaw2's Avatar
sothpaw2
Default Do 17-11"s help at Drags?
Mr Mojo or any of you other Drag racers,
If I'm using a good street tire, like GY F1 Supercar or GS-D3, Pilots, etc, is there a big advantage in adding the 3" of rubber that you get with 3153517's vs 2844017s? Or do people use 315 mostly for looks?
Also, is the a good street tire pressure closer to 20 psi or 25? I've been going with 25, have not had the courage to try 20 yet.
Old Nov 25, 2003 | 04:24 PM
vader86's Avatar
vader86
Default Re: Do 17-11"s help at Drags? (sothpaw2)
Yes they would help, in general. Added traction.
Tire brand is something else to consider though
Old Nov 25, 2003 | 04:43 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
I am sure they will help a bit.
That said, typcially an inch of height will add more traction ability than an inch of width. For example going from a 29 x 9 to a 30 x 9 will theoreticlly provide more contact patch than going to a 29 x 10.
Old Nov 25, 2003 | 05:35 PM
Bans25's Avatar
Bans25
Default Re: Do 17-11"s help at Drags? (LT-4 CE)
I think the one disadvantage of going taller rather than wider is the loss of handling corners etc.. This does not matter at the drag track, but sounds like he wants street tires. I would go wider rather than taller unless I was buying a set of drag radials.
Old Nov 25, 2003 | 05:58 PM
Vic'89's Avatar
Vic'89
I have never been able to hook up with any kind of street tire.
Vic
Old Nov 25, 2003 | 06:00 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
This guy upgraded from 9.5" rims to 11" rims on his T/A. He realized a net LOSS of 3.6 rwhp and 3.5 lb/ft. The likely reason is extra weight.
http://www.ws6.com/wheels.htm
rcolling's Avatar
rcolling
For drag racing they did not help me. My 60's were only very slightly better after the 315s were added. I attribute that to new tires rather than 315s.
However, I am absolute terrible at launching.
Best I could do on any street tire was a couple of 2.08s but was usually in the mid 2.1s.
What did help was DRs.
Old Nov 25, 2003 | 07:53 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I recently switched to 11" rims and 315-35-17 Sumitomo tires...they are pretty soft with a treadwear rating of 160...my 60's didn't drop very much but my spin was reduced dramatically....2 weeks ago I put in a 24-2600 stall converter and my 60's dropped a full tenth !....I'm averaging just under 1.91 now.. :D ...my ET's haven't dropped too much cause I have 9.5" rims up front with 275-40-17's...btw, all four Sumi's from Tire Rack cost $526.00...
I race with about 25 lbs. in the rears and 42 lbs. in the fronts... good luck
Old Nov 25, 2003 | 09:10 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
According to Dragmaster Extrordanaire MackeyRed96, the skinniest tire you can get without spinning is all that's necessary, so in other words, if you are hooking with 285's, there is no need to go with 315's.
Mackey himself has gone to 325/50R15, they are 28" tall and provide a huge contact patch, but he needs it.
I hooked pretty good with 285's, they were Michelin Pilot XGT Z4's(best damn tire in the world) at 30 psi. Lowering the psi too much can cause a negative effect by letting the center of the tread cup inwards. In essence it would be like riding on two bicycle tires. You just have to keep experimenting with tire pressure. On drag radials I'm at 22 psi hot, on the street tires I was at 28-30 psi cold.
As mentioned above, when I went to 315's I lost a little, I think mostly due to the extra weight.
To Do 17-11"s help at Drags?
