95 opti in a 92
Old Nov 25, 2003 | 04:22 PM
Frank92's Avatar
Frank92
Default 95 opti in a 92
hi,
does a 95 opti spark fit in my 92 lt1 (without mods)?
thanks frank
Old Nov 25, 2003 | 04:34 PM
Tom Piper's Avatar
Tom Piper
Default Re: 95 opti in a 92 (Frank92)
No, the '95 vented Opti-Spark is different than the '92.
Here is what I had to change to get the '95 Opti-Spark to work in my '92:
1) Camshaft -- the early LT1s have a broached hole in the front of the camshaft that is too small for the later Opti-Spark to fit into. I'm told that in about '93 that was changed, so you may not need a camshaft change for the '93 and up. Plus, the dowel pin is too short in the camshaft -- you need a longer one for the later Opti-Spark.
2) Front cover -- the later Opti-Spark needs a larger hole in the front cover.
3) Timing Gear set -- the early Opti-Spark is driven from the cam gear, the later Opti is driven by the dowel pin in the camshaft.
4) Electrical harness extension -- the '92 is unique here.
5) You also need a way to adapt the vacuum harness -- this is an easy change.
I think you can buy a Dynaspark that is already set up for your car with the vacuum venting.
Tom Piper
Old Nov 25, 2003 | 06:21 PM
Strick's Avatar
Strick
Keep it simple, go with the Dyna Spark. Check out the left column under DynoTech. It may cost a little more but itis well worth it.
To 95 opti in a 92
