Stripped out treads?
Old Nov 27, 2003 | 12:04 AM
MongooseLT4's Avatar
MongooseLT4
Default Stripped out treads?
One of my bolt holes for my power steering pump has striped itself out, I'm going to use Form-A-Thread to repair the problem. Has anyone else used this or have any suggestions on something better?
Old Nov 27, 2003 | 02:42 AM
ZR1 32 16 405's Avatar
ZR1 32 16 405
7th Gear
Default Re: Stripped out treads? (MongooseLT4)
well.. i have always drilled it out put in the proper size Heli-coil.. this is better because it actually makes the hole stronger.. but the only hard part is that you probably might not have enough room.. if its on the block correct? :confused:
Old Nov 27, 2003 | 02:54 AM
BAM92's Avatar
BAM92
Anychance you could drill and tap it one size bigger? Maybe go from metric to sae. Good luck sounds like a pita anyway you look at it.
Old Nov 27, 2003 | 03:05 AM
BIG JIM 54's Avatar
BIG JIM 54
I want to hear about the "stripped out tread" that your topic implied.
BIG JIM
Old Nov 28, 2003 | 10:00 AM
SouthernSon's Avatar
SouthernSon
Default Re: Stripped out treads? (BIG JIM 54)
The stripped out tread on my rear tires comes from too much throttle. (sorry, I couldn't resist). But yeah, what he said, helicoils is the only way to go. :steering:
Old Nov 28, 2003 | 12:35 PM
xs650's Avatar
xs650
Make everything very clean and follow the directions carefully, you don't have much to lose and it stands a fairly good chance of working.
If you want to be sure and have access room and enough meat left to get a Heli-coil installed, that's better.
Dick
Old Nov 29, 2003 | 03:22 PM
MongooseLT4
Default Re: Stripped out treads? (xs650)
Thanks guys, I got to looking at it yesterday and found of that its not the block as I thought at first but actaully a bracket, so I ordered a new one.
To Stripped out treads?
