HP with motor combo
Old Nov 29, 2003 | 05:17 PM
91superram's Avatar
91superram
Default HP with motor combo
What horse power numbers and 1/4 mile times with the following combo
-355 with flat top pistons 10.5 compression
-stock 113 heads with springs
-ZZ9 cam
-Superram intake with ported base
-3:54 gears
Old Nov 29, 2003 | 05:19 PM
Corvette0096's Avatar
Corvette0096
Default Re: HP with motor combo (91superram)
Best I could get out of my stock form #113 was 13.00 That was with a super ram and a 219 and 3.07
Old Nov 29, 2003 | 05:25 PM
91superram's Avatar
91superram
Default Re: HP with motor combo (Corvette0096)
Was that with a stock tire?
Do you think the 3:54 gear would put it in the 12's
Old Nov 29, 2003 | 06:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
That should give you 12s potential if you can hook it up; on street tires you will play hell to hook up.
Vit'89 has been running well into the 12s this season on DRs with stock cam and 3.07 gears.
Have you done the simple mods?
Old Nov 29, 2003 | 06:56 PM
Corvette0096
I was almost doing a 1.79 on street tires. Pepboys. :yesnod:
Old Nov 29, 2003 | 08:11 PM
vader86's Avatar
vader86
upper 12s, maybe a mid 12 if you get lucky
probably a little more than 350chp
Old Nov 29, 2003 | 08:58 PM
91superram's Avatar
91superram
Default Re: HP with motor combo (vader86)
What about some porting and polishing with the stock heads
and some 1.6 rockers
[Modified by 91superram, 9:03 PM 11/29/2003]
Old Nov 30, 2003 | 04:08 AM
mistaben's Avatar
mistaben
:lurk:
To HP with motor combo
