Anyone running Accel header plugs?
Old Nov 30, 2003 | 10:38 AM
Red Tornado's Avatar
Red Tornado
Default Anyone running Accel header plugs?
Summit #ACC-8198, $23.95 for set of 8.
I've been considering the AC Rapidfire #5's, possibly NGK TR-55 (although shorter lifespan).
Are the Accel units really good plugs? These have a U-groove. Performance? Supposedly these avoid dimpled headers, burned/melted plug boots & plug changeout difficulties due to their shorter length.
Or is a standard plug like the Rapidfires still the way to go, even with headers?
Any opinions, advice?
Also, I'm still wrestling with getting either Taylor 8mm Spiro Pro or MSD 8.5mm ignition wires :confused:
[Modified by bradvette, 10:52 AM 11/30/2003]
Old Nov 30, 2003 | 11:59 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: Anyone running Accel header plugs? (bradvette)
Bradvette,
The only reason I used the header plugs-they took care of the problem I had with #7 boot burning on the header. The plugs are OK but if NGK's will work, I would go with them.
You are paying for the plug being shorter, not necessarily a better plug.
Jim
[Modified by 85vet, 12:00 PM 11/30/2003]
Old Nov 30, 2003 | 12:02 PM
VetteNoob's Avatar
VetteNoob
Default Re: Anyone running Accel header plugs? (85vet)
:iagree:
Or go with the Rapidfire plugs if they will fit.
To Anyone running Accel header plugs?
