Overspray Paint Removal
Old Nov 30, 2003 | 02:42 PM
DESPERADO's Avatar
DESPERADO
Default Overspray Paint Removal
I recently got a set of new, never installed, front spoilers from EBay. Unfortunately it wasn't mentioned that they were covered with paint overspray.
Does any know of the best method to remove the paint without fading or in any other way affecting the plasitc? I tried using paint thinner, it works but it's incredibly slow.
Old Nov 30, 2003 | 02:49 PM
1990CORVETTE's Avatar
1990CORVETTE
Default Re: Overspray Paint Removal (DESPERADO)
TRy a mother's clay bar
Old Nov 30, 2003 | 09:15 PM
no_radio's Avatar
no_radio
Default Re: Overspray Paint Removal (1990CORVETTE)
Yep, clay bar is the safest bet.
Jeff
Old Nov 30, 2003 | 09:34 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
You could just paint them black????
Old Nov 30, 2003 | 09:36 PM
LD85's Avatar
LD85
Default Re: Overspray Paint Removal (edsalinas)
Flame me now but thank me later,,,,, nail polish remover,,, trust me!
Old Nov 30, 2003 | 09:43 PM
DESPERADO's Avatar
DESPERADO
Default Re: Overspray Paint Removal (ld85)
Ok but instead of being a Nancy using $0.50/oz nail polish. Acetone is the active "ingredient" in nail polish remover and costs a hell of a lot less and isn't full of perfumes!
Thanks guys, I'll go with the acetone.
[Modified by DESPERADO, 7:44 PM 11/30/2003]
Old Nov 30, 2003 | 10:04 PM
edsalinas's Avatar
edsalinas
Acetone will work, just don't leave it on too long......
Old Nov 30, 2003 | 11:31 PM
TA's Avatar
TA
:iagree:
Old Dec 1, 2003 | 12:14 AM
Sam Lam's Avatar
Sam Lam
I have used Acetone to remove paint and any clay bar (Auto Zone, NAPA, Advance, etc) will easily remove the overspray without harming the base paint.
Old Dec 1, 2003 | 07:59 AM
LD85's Avatar
LD85
Nancy here , nail polish remover cost less than $1.00 for a bottle of 8 ounces, you won likely use/need a whole bottle.
I agree with the acetone but I can get my wife to clean her nails with it! :lolg:
Old Dec 1, 2003 | 11:46 AM
DESPERADO's Avatar
DESPERADO
:cheers:
Old May 18, 2017 | 11:46 AM
Nancy J Zeman's Avatar
Nancy J Zeman
2nd Gear
How to remove overspray paint on a glass top of a C-5
Old May 18, 2017 | 10:08 PM
A Peter C4's Avatar
A Peter C4
Would clay bar work on the rough surface of an air dam-front spoiler ?
Old May 19, 2017 | 02:41 AM
Hot Rod Roy's Avatar
Hot Rod Roy
No.
Old May 19, 2017 | 05:19 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Be careful of acetone on plastic. It will melt certain formulations. I tried pouring some in a plastic bottle, melted right away.
What type of thinner are you using to try and remove the paint ? I removed overspray from some plastic inner fender splash shields I am helping a friend do a restoration of a 73 Buick Riviera Boat Tailed coupe. We are finishing a up a ground up resto on a show car.
I used lacquer thinner. Put it on and let it sit a bit and it cut down through. You might want to buy a throw away tin foil pan so you can submerge sections to let them soak.
Get some BLUE non-scratching scotchbrite. any other color will dull down the finish (abrade the plastic). IIRC Lowe's has blue. We use it for scrubbing the outside of our stainless pans. Let the lacquer thinner work and hit it with the scotchbrite.
Clay bars are for removing micro particles of contaminants in paint pores.
Old May 19, 2017 | 10:03 PM
A Peter C4's Avatar
A Peter C4
Would it be easy'r to just paint the spoiler/air dam with black plastic approved paint?
To Overspray Paint Removal
