Correct procedure for valve lash/lifter pre-load.
Old Dec 1, 2003 | 10:24 AM
Mark L. Warner's Avatar
Mark L. Warner
Default Correct procedure for valve lash/lifter pre-load.
There are so many different theories - what is the correct procedure adjusting valve lash/lifter pre-load for an engine that is already broken in, but will not be running when the adjustment is made? :confused:
Old Dec 1, 2003 | 10:40 AM
CFI-EFI's Avatar
CFI-EFI
Default Re: Correct procedure for valve lash/lifter pre-load. (Mark L. Warner)
There are several, good, acceptable, methods. It can get to be a controversial subject, with one person claiming his way is the only way, and the next, that his is. This has been hotly debated on here recently. In lieu of a manual, I suggest you do a search on the subject. Good luck, and...
RACE ON!!!
