LT1 TICKING SOUND
Old Dec 2, 2003 | 09:28 AM
BOB R.'s Avatar
BOB R.
Cruising
Default LT1 TICKING SOUND
I have a 1995 coupe that I have had since new.I have never had any trouble with it at all,but recently I have heard this ticking sound in the engine especially when I pull in the garage it runs fine and has 40 thousand miles and has been serviced every 3 thousand miles.I am kind of worried has anyone experienced this problem hopefully I could fix this myself.thank you BOB R.
Old Dec 2, 2003 | 10:12 AM
bogus's Avatar
bogus
Default Re: LT1 TICKING SOUND (BOB R.)
welcome!
I would think it's the injector's. They are noted to make noises....
Old Dec 2, 2003 | 10:17 AM
Goody's Avatar
Goody
Welcome :seeya . Are you sure it isn't just the normal LT1 noisey injectors?? Where does the sound seem to be coming from? My injectors are somewhat noisey and have been for the 5 years and 60K miles I have added. I now have 148K on it.
Turn off all the lights at night in the garage and then start the car. Look at the engine while it is running and look for a blue haze or cross arcing plug wires to eliminate that as a cause.
I'll still guess it is the injectors. Some might be dirty having not seen much action with low mileage use. Allows additives to develope in the fuel system which may add to the issue. A good cleaning might help with this. A place called crusin' performace does injector cleaning and balancing at a real reasonable rate.
Old Dec 2, 2003 | 10:25 AM
ittlfly's Avatar
ittlfly
Default Re: LT1 TICKING SOUND (Goody)
:iagree:
Rich at cruzin in performance will take care of you if your injectors need service. AND he will take the time to talk to you if you have concerns.
Old Dec 2, 2003 | 11:14 AM
ninetyfivevette's Avatar
ninetyfivevette
Default Re: LT1 TICKING SOUND (ittlfly)
Could a person switch to a different brand injector, like FMS for instance or are these just as noisy?
Is there a "quiet" injector?
Old Dec 2, 2003 | 03:15 PM
warren s's Avatar
warren s
Default Re: LT1 TICKING SOUND (ninetyfivevette)
Other non stock injectors make the same sound.
Before I bough my 95, I was beginning to think that every Vette I looked at had sticky lifters, mine sounds the same in the garage, did since i got it at 12,800 miles and mow at 25,000.
To LT1 TICKING SOUND
