Speedo correction
Old Dec 3, 2003 | 10:53 AM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Default Speedo correction
I'm going from 3.54 to 3.73 gears. Since I have a '93 I need to change the speedo gear. Anyone know which one I need? Maybe a part number?
:cheers:
Old Dec 3, 2003 | 11:19 AM
scorp508's Avatar
scorp508
Default Re: Speedo correction (Rex Ruby)
You need the one that drops your speed down by 5.0938%. :jester
Old Dec 3, 2003 | 11:27 AM
Rex Ruby's Avatar
Rex Ruby
Default Re: Speedo correction (scorp508)
I need something I don't know :smash: :lol:
Old Dec 3, 2003 | 07:29 PM
Rex Ruby's Avatar
Rex Ruby
anyone :)
Old Dec 3, 2003 | 09:24 PM
RogueVette's Avatar
RogueVette
Cruise-In III Veteran
Rex, from what EricVonHa has told me it seems as though this is for a 93 ZF car, right? If so, you're stock rear end ratio is a 3.45. This is important when you talk to Cyberdyne. They make an electonic interface that converts the speed sensor output of your trans without having to take the trans apart! Here is a link: http://www.dougrippie.com/drm/drive_...tm#Speedometer Calibration Service
Old Dec 3, 2003 | 09:48 PM
FL KEYS ON's Avatar
FL KEYS ON
anyone :)
Is tranny auto or 15 teeth gear drive on zf? you need to know the teeth count that's on your tranny now (sleeve). Sleeve - grey is 15 teeth, red would be 17 teeth. (you may need to reduce ...... depending)
# Driven Gear Teeth = [ [(20168/Tire Diameter in inches)] x #Drive Gear Teeth x Axle Ratio ] / 1001
If you, for example, have a 25" diamater tire, 15 teeth sleeve gear, and want 3.73 ratio, then you would need a 45 teeth driven gear according to the above formula.
GM parts numbers for speedo gears are:
Part No. Teeth Color
25513042 35 Orange
25513043 36 White
25513044 37 Red
25513045 38 Blue
25513046 39 Brown
25513047 40 Black
25513048 41 Yello
25513049 42 Green
25513050 43 Purple
25513051 44 Dk Gray
25513052 45 Lt Blue
I know finding spedo calibration gears for 4.10 requires the 13 teeth sleeve, which is pretty hard to find -- and pricey if you can find them.
Perhaps other can jump on and confirm the above, but pretty sure this is fine.
To Speedo correction
