4-Bar Link.....How..
Anyone every use one of these setups in steet/strip application? I realize I will loose some handling by going to one, but I seldom test the limits of the corning of the car on the street. I figure I test the car enough in a straight line and give it a break on the curves :D
I see most of the 4 link use a side to side, diagonal rod to reinforce corning stability, and i suppose it could be beefed up to improve corning.
I would like to hear is anyone has every done this sucessfully on a 4-link.
I have been looking at the possibility of a bolt in 4link for these cars. I have it pretty well hashed out, at least in my mind, and through pictures,but on of the big questions is corner stability.
I would like to hear from some that maybe had a true 4-link in cars and how they behaved on corners. Again, I am looking for something that can handle normal to moderate street cornering. No autocross actions ect.
Thanks! :cheers:
Of course, it will make the car jumper overroad irregularities while in corners.
Think of it as turning your corvette into a camaro without a back seat. :D
Here is a shot of the rear housing I am thinking about having made up with the 4-link brackets located to proper spots:
I am also thinking about an 8.8 rear housing also. This might be easier and more cost effective since they are readily available in most junk yards. Brackets would also need added to the end, to allow use of the rear brakes/calipers. Not sure about the ABS still being able to be used, I have not got that far.
Ultimately I would like to see a complete bolt in setup, so if I wanted to change everything back to the IRS, it wouldn't be a total nightmare, and the car would not be altered beyond that possibility. Thus far its looking like its more than possible :cheers: :thumbs:
[Modified by ski_dwn_it, 8:44 AM 12/4/2003]
but a live axle is not better than IRS when it comes to cornering.
If live axle WAS better, then all the high end sports car makers never would have gone to IRS...
It is better for drag racing, tho... less parts to break.
What setup would you suggest? Just a beefed up bar? Or one that comes off the rear of the axle to tie it all together on a diagonal.
I realize it will not handle like the car does now. But most of my driving is just a cruise here or there, and seldom hammer on it on the street through corners. But I do not want to worry about damaging something or loosing control on the street with the car if something would be stressed enough to break. If someday the urge to drag race the car fades. Then I want to be able to easily change it back to IRS system for handling again.
I just think the benefits of the solid axle on the strip, for my use now would greatly outweight the IRS benefits I use on the street now. I would like to be pushing 1.3x 60' times or lower with the new setup. Somewhere around where Hooked Up is at now.
:cheers:
See the conundrum I'm in?? As for lateral movement for a 4-link or ladder bar what you're referring to in the "diagonal bar" is a Panhard bar...It positively locates the rear in the center of the car and prevents lateral movement. The Panhard is the simplest way of doing this; a more complicated but better way is a Y-shaped sliding locater that has it's two legs of the "y" attached to the diff and the center pole (which slides back and forth to allow vertical movement) is attached to the rear crossmember (there's that DAMNED crossmember that DOESN'T exist, again)...
As for handling, a properly setup 4-link or ladder bar will handle better than most people are capable of driving...Remember, NASCAR's are solid axle setup and they handle pretty damn well...
-Jeb
If you are going to be doing mostly drag racing (I assume you are, otherwise why bother?) just do a four-link with a panhard bar and you'll be fine. This pic shows both:
The diagonal link is the one in front of the axle at about a 45 degree angle to it, the panhard bar is the one parallel to the axle. The panhard bar is the one you want.I would stay away from ladder bars because they bind when the axle is not parallel to the body (i.e. when one wheel hits a bump or when the body rolls going around a corner). It basically uses your axle as a sway bar. It's fine most of the time, but can fail with a lot of street use. Non-parallel four links can bind a little too, but it's not as problematic.
jburnett: The Watt's Linkage can be used with any of the other suspension, it is just the lateral locating device. You could also get a Shaw Link to do the same thing, but like the Watt's Linkage I think they are both overly complex for anything that isn't going to be set up purely for road racing. A panhard bar isn't perfect, but it's simple and doesn't take up much space.
As for NASCAR, they handle well, but they don't have to worry about irregularities in the track either. Their suspension is just a refined version of what's in my '68 pickup, two long trailing arms that angle inwards towards the front and a panhard bar.
