N2O.....
Old Dec 5, 2003 | 01:02 PM
JJ 86's Avatar
JJ 86
Default N2O.....
I'm in the planning stages of my next mod. I'm looking to install a N.O.S. adj. wet kit up to 150hp shot. I'm still fairly new to the do's and don'ts of N2O so is there any tips or anything i should know before i actually buy a system? Thanks for any help!
current status:
'86' L98, A4, 2:59, Lt headers, 2.5" flowmaster exhaust, 160 stat. and K&N. :smash:
Old Dec 17, 2003 | 08:27 PM
red-y's Avatar
red-y
Default Re: N2O..... (JJ 86)
Stay with 100 shot
Use a throttle body activation switch and a window RPM switch.
Have fun :seeya
[Modified by red-y, 7:28 PM 12/17/2003]
Old Dec 18, 2003 | 12:15 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
The more safty things you have the better off you will be... Take your time on the install and do it right, NO short-cuts.... If you have any questions ask...
Old Dec 23, 2003 | 05:04 PM
redfast's Avatar
redfast
Default Re: N2O..... (fsr402)
:iagree: with the 100hp shot, any more with the stock engine internals may be risky. Thats my opinion
Old Dec 23, 2003 | 05:17 PM
krivera's Avatar
krivera
Default Re: N2O..... (redfast)
i would say 150 shot with the right tuning. I would pull timing out and change plugs and go with a good aftermarket ignition!
You should be fine as long as it is tuned right!
What you do is run a quater mile and before letting off the gas kill the car and the NOS coast to a stop and then check the plugs if they are anadized looked like a blue or pinkish then it is lean lean! make sure your fuel pressure is up and i would tune it on a dyno to check air/fuel so you dont run lean and burn up the motor!
i ran a 150shot with 10psi of boost!
but then again i was trying to blow the motor but i did run a 150 shot for awhile here is a vid clip http://www.speedmafia.com/383d1/index.htm
or http://www.speedmafia.com/Street%20R...3.2%20boy!.MPG
Old Dec 30, 2003 | 05:26 PM
fiberglasscoffin's Avatar
fiberglasscoffin
i use a 150shot and dont pull any timing i have used over 20 bottles and my motor has over 90,000 miles still going strong i use sunoco gt 100 gas and msd 6al and a rpm window switch at 3000rpms
To N2O.....
