Help... brake lights won't go off!
Old Dec 5, 2003 | 08:51 PM
Triple Black 88's Avatar
Triple Black 88
Default Help... brake lights won't go off!
I replaced the Power Brake Booster yesterday...and now the brake lights wont go out, even with the car off. I had to pull the fuse. Any idea whay could cause this?
:flag
Old Dec 5, 2003 | 09:17 PM
SPEED750's Avatar
SPEED750
Default Re: Help... brake lights won't go off! (Triple Black 88)
You need to readjust the switch on the pedal.Brake lights on all cars will activate with the key off, I think it's a safety thing. :chevy
Old Dec 5, 2003 | 09:21 PM
86PACER's Avatar
86PACER
There is a small electrical button that the brake pedal arm presses when you step on the brake pedal. Its under the drivers panel. You cant miss it. It sits very close to the brake pedal lever and this is what turns your brake lights on when pushed. I would make sure that it has a small gap between it and the brake pedal arm. The gap between it and the brake pedal arm should close enough as to depress when you just tap your brakes, but not touch the brake pedal arm when released. You might have disturbed it accidentaly when you unbolted the nuts under the dash to remove your brake booster. Hope this helps you. Good luck.
Old Dec 5, 2003 | 10:05 PM
Triple Black 88
Default Re: Help... brake lights won't go off! (86PACER)
Thanks guys, that helps a lot.I actually remember seeing 2 white button contraptions, so one of them must be the one. We got about 2" of snow today so I'll try to get to it tomorrow.
If 1 button controls the brake lights, what's the other one for?
Old Dec 5, 2003 | 10:23 PM
Kens86's Avatar
Kens86
The other one is the release for the cruise control.
Old Dec 5, 2003 | 10:25 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
I think I would seperate the booster from the master again and check the adjustment of the rod that interfaces from the booster to the MC. This is adjustable and if too loose would allow your pedal to hang lower then the previous booster.
Compare the new to the old using a straight edge and feeler guage. Adjust the new accordingly, perhaps allow just a little more slop to account for changes when under vacuum. May take a couple of trys.
Be careful, as too tight will drag the brakes (which might not be apparent until driven quite a bit and they heat up and drag hard).
Old Dec 5, 2003 | 10:39 PM
Triple Black 88
Default Re: Help... brake lights won't go off! (PeteL)
Pete, how do you adjust the rod? I already returned the old one for the Core refund so I can't compare, but let me add this. The pedal goes to the floor with out resistance and then stops the car like normal. The brakes were bled alond with a new MC about 2 mo's ago. Would this also have anything to do with the rod adjustment? If so, how do you adjust the rod?
Old Dec 5, 2003 | 10:51 PM
PeteL's Avatar
PeteL
The rod has a nut end and can be screwed out or in. Out lifts the brake pedal, but can cause brake drag if too tight. In drops the brake pedal, but may not provide enough range for full braking.
You may have a seperate problem with bleeding and air in the system. Compare first to the immediate state before the change of the booster and try to match. Then work on bleeding to restore proper braking.
I can't tell you how many threads on this C4 forum I have read where air in the system was a major problem for the owner.
I had to adjust the rod on my new booster three or four time until I got the pedal where I wanted it. It's really not that much work to seperate the booster and try several adjustments...just a few turns at a time. Be careful of bending the brake lines on the MC, move just enough to allow the adjustment.
Old Dec 5, 2003 | 10:57 PM
Triple Black 88
Thanks for all the help!!! I will give it a try tomorrow. In no way am I a mechanic, so your help and instruction is greatly appriciated!!!
:flag
To Help... brake lights won't go off!
