When you installed the yokes in your differential for the half-shafts, did you make sure the saddles for the universal joints, left vs right, were phased 90 degrees apart?
This is supposed to keep vibration down in the drive line.
Re: Phasing the differential half-shaft yokes.... (Tom Piper)
Do you mean side to side...meaning right 1/2 shaft to left haftshaft? Or on the same 1/2 shaft?
The 1/2 shafts have molded sadles off them that do not allow different phasing of the u-joints. So this leads me to believe you mean phasing the 1/2 shafts side to side, which might smooth thing till you either spin your tires, or make a turn at which point you will mess that phasing all up. I guess what I am getting at is the 1/2 shafts are always phasing in and out past 90* of one another.
So I either do not get what your talking about, or you were fed wrong information, and hence the reason no-one has replied to you post. :cheers:
How hard is this to understand? :D He is talking about the yokes in the differential being 90* off. With that said I don't see the point since it is a posi rear end.
Re: Phasing the differential half-shaft yokes.... (ski_dwn_it)
I guess the manual means sid to side.
I'm thinking the same thing you are -- see my post above yours.
Maybe I am misunderstanding the '63 manual, but I think this is what it means.
I don't see how you can change phasing on one side.
From: SCMR Rat Pack'r Charter Member..Great Bend KS
You guys who maintain that side-to-side phasing will be gained and lost through differential are correct. Whether the differential has limited-slip or not doesn't matter.
And one-piece driveshafts have proper phasing when they are assembled (hopefully).
I have to phase the driveshaft on my Chevy van...because it has a two-piece unit.
Universal joints have to be "in phase" for the length of the shaft; between the power source and the driven member. The u joint phasing in the half shafts is established when the weld yokes are welded into the tubing. Any attempt to match rotational angles from one half shaft to the other would be... I couldn't find my 1963 service manual. This is the C4 Tech section. Will my 1983 manual do? Since most of us don't have 1963 manuals, can you quote what you are refering to, to us? Something doesn't make sense, here. Good luck, and...
Re: Phasing the differential half-shaft yokes.... (CFI-EFI)
I think you're reading too much into it; I suspect the instruction means to rotate the differential side yoke to be 90 degrees in relation to the axle shaft yoke so that the U-joint can be placed in it's proper position to be bolted in.
In short, I think the shop manual is simply stating the obvious, and that it has nothing to do with the two differential side yokes being 90 degrees with respect to each other.
From the '63 shop manual.
"Place driveshaft inboard trunnion into side gear yokes and assemble U bolts. Rotate yokes so that trunnion seats are phased 90 degrees apart."
If you ignore the C4 5 link suspension compared to the C2 3 link suspension, there is very little difference between the C4 and C2 when it comes to the rear driveline. I own a '64 and a '92. I think, because there are more C4 owners than C2 owners, I seem to get more people involved in a conversation on this forum. I also posted the link to this thread on the C2 forum.
Re: Phasing the differential half-shaft yokes.... (waynec)
You may have something there.
Sounds like it is too obvious for my mind to grasp -- kinda like telling me I have to breath.
When I read this in the manual, I remembered an article that compared u-joints to constant velocity joints. That article was talking about making sure u-joints were phased 90 degrees to cancel "whip" caused by the u-joints. But, with constant velocity joints, it wasn't necessary to phase them.
