stroker 383??
Old Dec 7, 2003 | 03:33 PM
Ozman's Avatar
Ozman
Default stroker 383??
Just what exactly is this engine. Obviously 383 ci, but what else can someone tell me about it?
Also, has anybody had experience with Lingenfelter Performance Engineering. I'm thinking about spending some bucks on my Vette.
I need some more performance.
Old Dec 7, 2003 | 04:00 PM
Curveit's Avatar
Curveit
Default Re: stroker 383?? (Ozman)
A 350 block(4" bore) with a 400 crank(3.75" stroke). 1/4" stroke increase= more Torque, and HP. Needs to use 400 flywheel/flexplate, and harmonic balancer; sometimes a starter change.Some grinding on the bottom of the cylinder bores for clearance, usually a smaller base cam is needed. All parts are readily avaliable,and not too expensive. Do a search and you will find plenty of info. on this.
:chevy
Old Dec 7, 2003 | 04:11 PM
Ozman's Avatar
Ozman
Default Re: stroker 383?? (Curveit)
thanks
Old Dec 7, 2003 | 04:48 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
:chevy
Bingo...... Very good info. LPE has a very good reputation.....
:thumbs:
Old Dec 7, 2003 | 06:00 PM
93Quasar's Avatar
93Quasar
Default Re: stroker 383?? (edsalinas)
Actually I thought the 383 was a combo of 3.75 stroke and .030 overbore, not a 4" bore??
Old Dec 7, 2003 | 06:08 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: stroker 383?? (Jeff Hickman)
Bingo!
Also, a reduced base circle cam isn't necessary with the 3.75" stroke. Good luck, and...
RACE ON!!!
Old Dec 7, 2003 | 11:42 PM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
Maybe this place could help shed a little light on the cost of parts for a stroker. I'm tryint to decide on a stroker or a ATI Procharger...not sure yet but either way I'm shooting for about 500 HP and Torque. :steering:
Old Dec 8, 2003 | 12:07 AM
Curveit's Avatar
Curveit
Splitting hairs on the bore: simply defineing the block used. A reduced base cam is often needed, depending on the cam and rods used.
Bingo :chevy
[Modified by Curveit, 5:09 AM 12/8/2003]
Old Dec 8, 2003 | 12:14 AM
scorp508's Avatar
scorp508
[QUOTE] Splitting hairs on the bore/QUOTE]
Not really. A 3.75" crank with a standard 4.000" bore would be a 377ci which is a common combo when you toss a 350 crank into a 400 block. You need the 0.030" overbore to get the real 383.
Old Dec 8, 2003 | 01:07 AM
Curveit's Avatar
Curveit
Gezzzz guys. I was just trying to explain what a 383" was. A 400 crank in a 350 block. If you want to split hairs even further, Chevy sells a crate motor 383" that uses a 4.00" bore with a 3.80" crank.
A blower would make those numbers (500HP/500TQ) without much trouble, but they're not at all cheap.
:chevy
Old Dec 8, 2003 | 12:28 PM
93Quasar's Avatar
93Quasar
Sorry, wasn't trying to pick on you. You just mentioned the fact that clearancing is required on the block, just thought I'd point out the you need to have a bore job done while it is at the shop getting clearanced. FWIW, I didn't need a small base circle cam w/ my 5.7 rods.
Old Dec 8, 2003 | 06:24 PM
Curveit's Avatar
Curveit
I forgot to mention; if you use an O.E.M. crank, the main bearing journals will have to be turned down to the smaller 350 size. Aftermarket cranks are already the right size, and are readily avaliable. You would also need pistons for this application, unless you used 400 rods.(not the best choise).If I forgot anything, I'm sure someone will jump in. :D Still cheaper than a blower.
:chevy
Old Dec 8, 2003 | 06:44 PM
CFI-EFI's Avatar
CFI-EFI
4.030" bore X 3.75" stroke = 383 cid
4.000" bore X 3.80" stroke = 383 cid
4.000" bore X 3.75" stroke = Not 383 cid
Now if you really want to get your panties in a bunch, Chrysler built 383s for years. They even used two different blocks. The "B" and the "RB". They had different bore/stroke combs than the Chevy(s). Wadda ya think o that???
Old Dec 8, 2003 | 06:59 PM
Curveit's Avatar
Curveit
My dad was a Chrysler man; had 4 383"s in different cars. I Drag raced 383" Dodges until '67; U.S. Army had different plans for me. Couldn't afford a Hemi. NHRA F/SA
:chevy
Old Dec 9, 2003 | 10:04 PM
mistaben's Avatar
mistaben
stroke it first :smash:
then blow it :jester
:D
Old Dec 10, 2003 | 12:04 AM
ZD1's Avatar
ZD1
Default Re: stroker 383?? (Rich & Lisa_84)
My feeling on that is that you'll need to stregthen the bottom to make best use of boost/nitrous. You have to look at your gains and how do you want to get there. I'll nearly double my HP by stroking (needed a rebuild any way) and addind good heads/cam/MRIII/etc... A S/C would be cheaper but is limited to the cast pistons.
To stroker 383??
