85 starts by itself when battery is connected
Old Dec 15, 2003 | 08:32 PM
david85's Avatar
david85
Default Re: 85 starts by itself when battery is connected (dlmeyers)
Well here it is 7:30pm in texas and the problem is solved. As it turned out, the connection with the yellow wire had it, the yellow wire, in the wrong slot. It took a blade remover to get the yellow wire out, and into it's proper slot. I have no idea how this wire got pulled/pushed out of its slot. If anybody ever needs to change out column, make sure the wire don't come out of the connector. My thanks to everybody who wrote with suggestions...... Each was tried. I only wish I'd read the post from "dl" before I spent the evening under the dash.... thanks again all! :hurray:
Old Dec 16, 2003 | 09:49 AM
dlmeyers's Avatar
dlmeyers
Default Re: 85 starts by itself when battery is connected (david85)
Glad it's fixed.
dlm
Old Dec 16, 2003 | 06:42 PM
TheStef's Avatar
TheStef
ah ha! cool
I didn't help trouble shooting but I did guess right, the red cable was somehow tuching the yellow one.
Good job!
