90 Master Cylinder Problem
Old Dec 8, 2003 | 11:12 PM
lavaone's Avatar
lavaone
Default 90 Master Cylinder Problem
About 6 months ago I noticed that brake fluid is migrating from the front reservoir to the rear. Does it slowly but steadily, about 1/4" every 2500 miles. Winter's here so its time for bigger maintenance projects.
Anyone seen this? Is it time for a rebuild? Any recommendations on where I should go to get a complete rebuild kit?
Old Dec 9, 2003 | 04:03 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: 90 Master Cylinder Problem (lavaone)
You'll probably have to replace it eventually. It wouldn't hurt to try a rebuild kit, if it's a slow leak like you say, it might do the trick. You definitely don't want to be driving if it's bad. You'll have reduced or no brake pressure up front.
Don't try to rehone the cylinder either, it can't really be done with aluminum, its too soft.
Old Dec 9, 2003 | 06:57 AM
90Z51Vette's Avatar
90Z51Vette
Mine showed the same symptoms. I decided to replace it with a new master cylinder rather than spending the time and effort to rebuild. Hate to take any chances with my brakes.
Mark
Old Dec 9, 2003 | 01:18 PM
Tourney3p0's Avatar
Tourney3p0
Mine does this also. I asked about it a few months ago and was told to skip a rebuild and get a new master cylinder.
Old Dec 9, 2003 | 08:21 PM
lavaone's Avatar
lavaone
Any tips on where to get a good buy on a great master cylinder?
Who has rebuild kits?
Thanks!
Old Dec 10, 2003 | 02:47 AM
white90conv's Avatar
white90conv
Try to get a rbuilt cylinder with the reservoirs already installed. They are dfficult to remove from the old cylinder and install on the new one. GM suggests special tools for the job.
To 90 Master Cylinder Problem
