Shifter Wedge
Old Dec 9, 2003 | 11:52 AM
Ernest's Avatar
Ernest
Default Shifter Wedge
I am replacing my clutch in my '92 LT1.The metal wedge in the the shifter refuses to come out.Exhaust pipes came out easier than this.How do you remove it?Brute force? :cry :cry :cry :cry
Old Dec 9, 2003 | 12:36 PM
BAM92's Avatar
BAM92
Default Re: Shifter Wedge (Ernest)
I grabbed mine with a pair of adjustable pliers and carefully hit the pliers upward with a hammer. Good time to put in a short shifter if you havent already. Alot easier with tranny on the ground out of the car.
[Modified by BAM92, 12:37 PM 12/9/2003]
Old Dec 9, 2003 | 02:55 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
When I had to do mine I dropped the top (convertible) and stood over the shifter with pliers and gave it a good pull. Thos things are really in there so don't be afraid to give it everything ya got. :D
Old Dec 9, 2003 | 06:19 PM
Atok's Avatar
Atok
Clamp a pair of vicegrips on it, then tap it up with a small hammer. Worked for me.
Old Dec 9, 2003 | 08:38 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Shifter Wedge (BAM92)
:iagree: That's it, don't just grab it and pull with vise grips, you may end up with a black eye or worse.
To Shifter Wedge
