o2 sensor on 1986, help
Old Dec 9, 2003 | 04:48 PM
dmac's Avatar
dmac
Default o2 sensor on 1986, help
1. Can an o2 sensor be changed from above, without jacking the car up? I can reach it from above and can even get a wrench on it.
2. Can the o2 sensor be cleaned and put back in or should it be replaced? Had it replaced 11 months ago, but I am getting a code 32 and when I am driving at highway speeds and press the gas pedal a little the engine acts as though it is loading up. Help Please from those who know. Thanks
Old Dec 9, 2003 | 04:57 PM
ittlfly's Avatar
ittlfly
Default Re: o2 sensor on 1986, help (dmac)
If you can get a wrench on it then maybe you can. I'd soak it with a penitrant first before trying it tho. If it won't come loose you could let it heat up a little by starting the engine. Good luck.
Old Dec 9, 2003 | 05:08 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Whoa...don't touch that O2 sensor; code 32 is an EGR code!
If that code is thrown on the highway, either the EGR valve is not opening on demand or the temp. sensor is nor registering; if the code is thrown at start up the EGR valve is stuck open or the sensor or wiring is shorted.
Use the diagnostic method on my site (link in sig. below) to analyze the problem.
Old Dec 9, 2003 | 07:18 PM
ittlfly's Avatar
ittlfly
Default Re: o2 sensor on 1986, help (65Z01)
Hey Jim, good catch. Maybe I should read post(s) a little closer next time. I blew right over the "32"... :D
Old Dec 9, 2003 | 07:27 PM
65Z01's Avatar
65Z01
Default Re: o2 sensor on 1986, help (ittlfly)
ittlfly, I was burned by code 32 for big $$ just after I took delivery of my '88 (when books & tools were 3,500miles away), so am not likely to miss that one. :lol:
Old Dec 9, 2003 | 07:39 PM
dmac's Avatar
dmac
My local mechanic told me that the code 32 inferred that the fuel mixture was to rich and that is why the o2 sensor either needed to be replaced or cleaned from being fouled. Does this sound correct? If I can remove it and clean the sensor, it would save some money. But if people on this forum feel it should be replaced instead, I will do that, but it was just replaced less than one year ago. Will check the EGR also. thanks
Old Dec 9, 2003 | 07:48 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
there not that expensive, I'd just replace it...
Old Dec 9, 2003 | 08:06 PM
65Z01's Avatar
65Z01
Code 32 is an EGR code...period. This code is only thrown due to a malfunction in the EGR subsystem, or possibly an ECM problem.
To check your O2 sensor (along with the coolant temp sensor) use the ECM's diagnostic mode, as described on my site. This test (only needs a paper clip) will determine if the ECM is going and staying in closed loop, in which case both sensors are ok.
Old Dec 9, 2003 | 09:19 PM
dmac's Avatar
dmac
Thanks for the help, I really appreciate it. Will go to work on it in the AM. Thanks again.
[Modified by dmac, 2:21 AM 12/10/2003]
Old Dec 9, 2003 | 09:40 PM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
The man is RIGHT! :yesnod: :cheers:
Old Dec 10, 2003 | 09:13 AM
ittlfly's Avatar
ittlfly
If the ECM stays in closed loop then look close at the EGR. The valve and its solenoid can be checked on the car for proper operation.
Old Dec 11, 2003 | 01:34 AM
Mike's 86's Avatar
Mike's 86
Check for a vacuum line off also. I had a code 32 and found that I accidently knocked off a line.
Old Dec 11, 2003 | 08:57 AM
mash557's Avatar
mash557
Default Re: o2 sensor on 1986, help (Mike's 86)
I kept getting the code 32, replaced EGR temp sensor twice and didn't fix. Took the EGR valve off and it was totally plugged would not open with a 3 lb hammer!!!
To o2 sensor on 1986, help
