maybe they dislodged enough corrosion and slime to clog the heater core. You can try to reverse flush it and see if it will clear up. BE VERY GENTLE WITH THE 2 PIPES THAT COME OUT OF THE FIREWALL/CORE TUBES! You do not want to spring a leak from the heater core. Can purchase a prestone(typically) flush kit. It has a 3 way valve you splice into the line that drains the core. Hookup a garden hose and crank it to flush out. Drain grunge into a resovoir so that coolant doesn't go down the drain and pollute the environment :rolleyes:
Also search our archives here. Type in "no heat" like your title. You will find ALL the info :D
Do a little troubleshooting...... Get the motor warmed up. THere are two heater hoses on the passenger side firewall . Check them both for an equal amount of heat. if there is a signifigant difference the heater core is probably clogged. if they are the same temp. the control door is probably stuck shut.
