Engine Removal
Old Dec 9, 2003 | 11:28 PM
mothersworry's Avatar
mothersworry
Default Engine Removal
I am about to pull the engine on my LT1. :party: I have purchased an engine leveler for the hoist which has 4 chains extending form it. Where is the best place to hook the chains for removal?
Old Dec 10, 2003 | 12:05 AM
ZD1's Avatar
ZD1
Default Re: Engine Removal (mothersworry)
unbolt 4 intake bolts. you have may have to get longer bolts and thick/washers though...be safe
Old Dec 10, 2003 | 12:18 AM
BAM92's Avatar
BAM92
Default Re: Engine Removal (ZD1)
TPIS has what is called a Happy Hooker that bolt to the top of the LT1 intake to pull motor.
Old Dec 10, 2003 | 11:06 AM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Engine Removal (BAM92)
I did not have good luck when I tried using a leveler. I found it easier just to pull it without it. When I attach the chains, I use the bolt holes in the block. There is one up in the front by the coil (not in the head), and then I use one of the bellhousing bolts diaganol from the one in the front. I simply hook the chain so that when the motor comes out it comes out at a slight angle (10-15 degrees). I bought a real cheap leveler off Ebay so that may have been my problem. Took me about 30 minutes longer to drop the engine in using the leveler though.
Let the fun begin!
To Engine Removal
