Gas Milage
Old Dec 9, 2003 | 11:50 PM
Vettewood's Avatar
Vettewood
Default Gas Milage
Why am I only getting 20 mpg at best highway driving thats computer and calculator. Had car at a dyno shop for testing they ran eng. ****. exhaust gas they said it would pass emisions test if I had to. The car has no cats free mods and the ford 22# injectors I thought it was running rich but it is not.It has fresh tune up msd wires top end was off and cleaned and throwing no codes any ideas what to look at. thanks :chevy
Old Dec 10, 2003 | 12:11 AM
ZR-71's Avatar
ZR-71
St. Jude Donor '15
Default Re: Gas Milage (gary samuel)
How long have you had it? Has it always gotten that mileage?
Maybe you have a really low rear end gear that someone changed to. That would decrease your MPG some. :confused:
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
:lurk:
Old Dec 10, 2003 | 12:14 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Sounds like all is well with the motor but you can use the ECM's diagnostic mode (on my site, link in sig. below) to see if the ECM is going/staying closed loop.
Also verify tire pressure is in the low-mid 30s as rolling resistance can add up.
When you do the mileage check, use cruise on a flat stretch of highway.
Does instentaneous & average mileage show the same data?
Old Dec 10, 2003 | 01:43 AM
froggy47's Avatar
froggy47
I'd love to get 20 mpg, best I ever did on a tank was about 14.8 mpg. I do like to keep the tach in the power zone, though, I don't even know if 5th and 6th are there.
Old Dec 10, 2003 | 08:04 AM
Vettewood's Avatar
Vettewood
Thanks for the sugestions, the gears are 2.59 , auto, the shop said it stays in closed loop highway driving. I just read alot of posts here saying your getting 25+mpg hwy. I have had the car for 6 months so I dont know the best gas milage it ever did get.
thanks :chevy
Old Dec 10, 2003 | 08:49 AM
QuikZilver's Avatar
QuikZilver
You may want to look at replacing the O2 sensors. I just did that on my 93 with 156,000 miles on it and my fuel economy went up. If you have a lot of miles, it may be something you want to look at.
:cheers:
Old Dec 10, 2003 | 01:03 PM
Vettewood's Avatar
Vettewood
Forgot to mention that I just replaced a new o2 sensor with another new one. Are there any other things to check, would a coolant temp on the egr have an effect. The mechanic installed champion platniums which im going to change out for the ngk this weekend. :chevy
Old Dec 10, 2003 | 03:28 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
How fast are you driving?
At 65mph I get 26mpg. At 80mph, I get about 21-22.
My stock 85 never got over 22-23 at 65 or so, and above 75 I never got better than 20-21.
Old Dec 10, 2003 | 04:28 PM
65Z01's Avatar
65Z01
I think it is a tuning issue; use the self test to double check the closed loop issue.
My bone stock '88 (down to the Fram air filter) pulled 29mpg on the drive from Phoenix to NY when I was driving the car home. Now, with current mods on flat highway at 65mph and cruise set it pulls 31-32mpg.
I would look at that closed loop verification and maybe check for a leaking injector and check spark plug condition as well as base timing and such, even though it can currently pass emissions.
Old Dec 10, 2003 | 04:34 PM
aj1988's Avatar
aj1988
I have an 88 coupe auto and I routinely drive from KC to DFW and on the trip down I average just over 26 mpg. On the return trip I usually get around 25.4. I have made this trip at least 15 times in the last 3 years and the MPG rarely varies.
On my last trip, 1400 miles including intown of 400 miles, I had an average of 25.4 mpg.
Old Dec 10, 2003 | 04:56 PM
Goody's Avatar
Goody
Default Re: Gas Milage (froggy47)
My auto only manages the low 15's. Might be the 3.45's or the constant 80% throttle modes I am in all the time......hmmmm :banghead:
Old Dec 10, 2003 | 06:21 PM
froggy47's Avatar
froggy47
Default Re: Gas Milage (Goody)
80% throttle, stop babying that bad boy. :D
Old Dec 10, 2003 | 10:32 PM
Vettewood's Avatar
Vettewood
I will check all of the recomendations you-all have made. Sometimes the car gets alot less gass milage depending how crouded interstate is.
thanks :chevy
Old Dec 11, 2003 | 07:27 AM
fiddleplayer's Avatar
fiddleplayer
Have you actually calculated the gas milage using actual miles driven divided by quantity of fuel used? I see that you have changed injectors. I read in a post a while back the computer calculated MPG can be erroneous with aftermarket injectors. The best way to check is fill the car up, take a trip for a known distance, refill the tank and do the calculations. An error in your speedo or different tire size can also throw off the computer calculated values.
FP
To Gas Milage
