horse power and performance
Old Dec 11, 2003 | 12:44 AM
pizzaman34's Avatar
pizzaman34
5th Gear
Default horse power and performance
hi guys need some good advice.i just bought my first corvette and 1994 and want to boost it up alittle any advice if you had about 1,500 or 2,000 dollars.i see and hear so much between trottlebodies and exhaust.what would be the best investment. thank you. :banghead:
Old Dec 11, 2003 | 01:04 AM
vader86's Avatar
vader86
Default Re: horse power and performance (pizzaman34)
No throttle body upgrade until you enlarge the bottom end.
I would probably do headers and gears first, then change the cam to CC305, or you can always go to the LT4 Hotcam kit. Keep in mind that if you change cams you will need your computer reprogrammed.
Then I'd do head porting, and decide from there if I needed more.
[Modified by vader86, 12:05 AM 12/11/2003]
Old Dec 11, 2003 | 07:34 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
For less than 2,000, torque converter and gears.
Old Dec 11, 2003 | 09:35 AM
pizzaman34's Avatar
pizzaman34
5th Gear
Default Re: horse power and performance (vader86)
thank you where would you look for these items eckler's or do you know another.let me know thanks again.p.s. would i have to or should i change the exhaust system too.
To horse power and performance
