Hi my 1986 coupe late model glass top is cracked Iv been told other years will fit but can any one tell me exactily witch years will fit thanks :cheers:
They all have slightly different front mounts on the windshield header. You can buy the mounts for the later years and retrofit them to your car. Or try searching ebay for a top.
Ok so your saying that A 1986 to A 1988 will fit fine BUT A 1989 - 1996 I will need diffrent mounts ?? :cheers:
Correct, L86-88 will fit without modifications, a 89-96 top you would have to buy the header mount and new header trim pieces and retrofit them to your car. :cheers:
