How do you adjust the rear window?
Old Dec 12, 2003 | 03:33 AM
montie98's Avatar
montie98
Default How do you adjust the rear window?
Hello, I was told that the window could be adjusted from side to side but when I looked at it I looked like a special tool was needed?
Old Dec 12, 2003 | 09:35 AM
yellow86v's Avatar
yellow86v
Default Re: How do you adjust the rear window? (montie98)
If you are talking about alignment of the rear hatch you can access the back side of the hinge bolts. You need to remove the plastic interior halo panel. Then you will see some sound proofing material.Peel this material back and you will see 4 nuts that secure the hinges loosen but dont remove completly.The holes are slightly elongated to give you some play. Open the hatch and move it to where you want it and tighten the nuts. Close the hatch slowly to make sure the catch is in the right position,mine needed a little tweek.
Old Dec 12, 2003 | 10:01 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: How do you adjust the rear window? (yellow86v)
:thumbs:
To How do you adjust the rear window?
