I am in Dex Cool hell!!!
Old Dec 12, 2003 | 03:37 PM
montie98's Avatar
montie98
Default I am in Dex Cool hell!!!
Since flushing my old green stuff out and replacing with dex I have had the (geling) symtoms that others have described.Maybe I did not flush well enough, but damm this is awful.Now I seem to have a leak at my waterpump weep hole too,wich was definetly not there.THIS IS B*llpoopie
Old Dec 12, 2003 | 03:50 PM
vvv90's Avatar
vvv90
Default Re: I am in Dex Cool hell!!! (montie98)
:nonod: :sad:
Yet another reason to do what the General recommends.
Old Dec 12, 2003 | 04:11 PM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
You put dex in an 86? :confused:
I work at a Chevy dealer. I took the dex out of my 96 and put green in it.
Old Dec 12, 2003 | 08:06 PM
Strick's Avatar
Strick
Please dump that dexcool. Go to tools>tech tips>C4>look for flushing tool. Follow that and disconnect one of the heater hoses and flush out the core too. Then go back to the green stuff. Trust us on this one. :chevy
Old Dec 12, 2003 | 08:12 PM
Dark-Knight's Avatar
Dark-Knight
Strick is steering you straight... recomend you follow his advice. :yesnod:
Old Dec 12, 2003 | 08:31 PM
montie98's Avatar
montie98
I flushed it like crazy today and put in fresh dex, I thought that it would be better to do that than to go green-orange-than back to green.All seems fine for now but some of that stuff coming out during the flush was like paint!Ill keep you posted if something else develops in the next few days.
Old Dec 13, 2003 | 12:17 PM
884fun's Avatar
884fun
I learned all about the orange stuff the hard way. I replaced the heater core then was told about going back to the green. A few months later I replaced a 2 year old water pump and a radiator. I was rebuilding the engine and found the water pump problem. As the new engine was warming up for the very first time, the plastic tanks on the side of my radiator peeled away.
No more "Extended Life Orange Juice for Me" :nonod: :nonod: :nonod:
Old Dec 13, 2003 | 02:57 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:confused: :rolleyes: I guess you didn't get the messages people sent you :rolleyes:
Dex does not belong in an 86!
:seeya
Old Dec 13, 2003 | 06:53 PM
bogus's Avatar
bogus
Default Re: I am in Dex Cool hell!!! (jackdaroofer)
you can never remove all the contaminates with a simple flush. the only way you can go to Dexcool in a older car is rebuild the engine, replace every hose, the heater core and the radiator.
Old Dec 14, 2003 | 08:08 AM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Default Re: I am in Dex Cool hell!!! (bogus)
... the only way you can go to Dexcool in a older car is rebuild the engine, replace every hose, the heater core and the radiator.
as well as all the seals in contact with the coolant. Go back to the green stuff unless you're dropping in a '96 engine.
Old Dec 14, 2003 | 08:15 AM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
[QUOTE] :confused: :rolleyes: I guess you didn't get the messages people sent you :rolleyes:
:seeya [/QUOTE
Kinda annoying isn't it when people ask for a cure, get definite answers and continue to do the wrong thing... why bother asking?
Oh well, hope it works for him.
Mark
Old Dec 14, 2003 | 08:53 AM
ROCKY85's Avatar
ROCKY85
:iagree: :iagree:
DUMP THE DEX COOL!!!! I did and its great!!!! :cheers:
Old Dec 14, 2003 | 09:19 AM
dwestsr's Avatar
dwestsr
Default Re: I am in Dex Cool hell!!! (Strick)
I almost made the same mistake. I was all set to flush and refill with Dex cool in my 86 . I read about the problems with dex on the forum some time ago and did my flush and refill with the green stuff. I'll keep the Dex cool for my 01 Suburban and leave the Vette with what it was intended to have. Thanks Forum!!! :cheers:
Old Dec 14, 2003 | 10:23 AM
larryfs's Avatar
larryfs
before I knew better. I put dexcool in my 89 TPI F-body. then I started reading about all the problems... and then my 96 Impala had problems.
so I flushed the dexcool out of my F-body, no sludge, and I went back to green. never a problem with the F-body, green or orange.
Old Dec 14, 2003 | 11:55 AM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
I had thought about changing to the orange when I did my periodic flush but thanks to CF coming through again I will stick with the green.
When I flush my system I install a pipe T in heater hose which flushes the whole system. Another note is make sure air is purged out of block or the thermostat might not function and cause engine heating up to super hot.
I had my system flushed by a jiffy lube place and sure enough the block had air pockets and heated up on way home. I had to purge block when I got home and it cooled down.
To I am in Dex Cool hell!!!
