Wiper Motor Replacement - HELP!
Old Dec 12, 2003 | 04:55 PM
OnDVirg's Avatar
OnDVirg
Default Wiper Motor Replacement - HELP!
I had to replace the wiper motor on my 85 and forgot to look before I removed it. With the motor installed and in the park position, how should the arm be positioned? I'm having trouble getting this correct. Thanks.
Old Dec 12, 2003 | 05:44 PM
OnDVirg's Avatar
OnDVirg
Default Re: Wiper Motor Replacement - HELP! (OnDVirg)
Never mind...I figured this out. There is some sort of dogleg on the passenger side that was not setting correctly. I moved it around a bit and it worked fine. Just in case anyone else ever has this problem...
