REV Kit Experiences?
Old Dec 14, 2003 | 08:55 PM
No Go's Avatar
No Go
Default REV Kit Experiences?
I'm getting ready to assemble a 95 LT1 with a GM 847 camshaft (296/304 duration and .575/595 lift). I would like to spin the engine to 6800 rpm.
I will be using the Competition Cams Pro Magnum hydraulic lifters that use the factory lifter retaining system. Along with this I'm seriously considering a REV kit.
One that I'm looking at is AFR's Hydra Rev. One concern is its springs are mounted in an aluminum bar-doesn't look to be a metal shim there at all-durability is most important...
Does anyone have any experiences with specific models of rev kits?
Old Dec 14, 2003 | 11:50 PM
ZD1's Avatar
ZD1
Default Re: REV Kit Experiences? (No Go)
I know that Comp cam does not make a rev kit kit for hyd roller lifters...only flat tappat.
Old Dec 15, 2003 | 09:33 AM
LT4POWR's Avatar
LT4POWR
I've got the AFR Rev Kit and like it. Just make sure that you still get the correct valve springs. Mine pulls hard all the way to 7,000rpm w/ stock lifters. Pics are here http://forums.corvetteforum.com/zerothread?id=615523
Old Dec 15, 2003 | 06:58 PM
No Go's Avatar
No Go
Default Re: REV Kit Experiences? (LT4POWR)
How many miles do you have on it?
I'm glad to hear you were able to reach that rpm point...:D
Old Dec 16, 2003 | 09:36 AM
LT4POWR's Avatar
LT4POWR
Probably only about 3k miles. It's not my daily driver.
Good cam choice, it was on my short list. If I had to do it over again, I'd probably go w/ the GM847.
Old Dec 19, 2003 | 02:26 AM
JAKE's Avatar
JAKE
I'd been thinking about buying a rev kit I checked AFR's site and saw their's won't fit Crane or Lunati lifters.
I'm running lifters I bought from TPIS when I got the ZZ9 years back. Does anyone know who makes their lifters? (I'll bet it's Crane, the way my luck had been running lately).
Jake
To REV Kit Experiences?
