Polygraphite, everyplace?
Old Dec 16, 2003 | 12:18 AM
xs650's Avatar
xs650
Default Polygraphite, everyplace?
I plan to switch to polygraphite bushngs on my '96 C4 convert with standard suspension every place in the seuspension, steering rack mounts and differential mount that uses rubber now.
Is there any reason that you recommend not using polygraphite bushings at any particular location?
The rest of the suspension will be stock except for a shock rebuild with slight upgrade on the damping and probably a perfomance street driving wheel alignment.
