Electrical problem - hatch open light
Old Dec 16, 2003 | 09:23 AM
Mark L. Warner's Avatar
Mark L. Warner
Default Electrical problem - hatch open light
When I apply my parking brake, the hatch open light comes on along with the parking brake light. Any tips on where to start to correct this problem. It never did this before, but then I did some significant engine mods etc. and now it does it.
Old Dec 16, 2003 | 10:14 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Electrical problem - hatch open light (Mark L. Warner)
So, what mods did you do,,,, ? give some info as a place to start....
Old Dec 16, 2003 | 12:22 PM
Mark L. Warner
Default Re: Electrical problem - hatch open light (vinnies87)
I pulled the engine and trans (it's an '88) and rebuilt the engine and installed an ROD 6 speed. Engine rebuild: ported stock heads with big valves (2.02/1.60)-10.25:1 compression, 1.6 roller rockers, ZZ9 cam, miniram, SVO 24# injectors, MSD, modified MAF, AIR pump delete, new alternator, Bosch +4 plugs, TPIS Level VI PROM, true dual exhaust, etc.
Old Dec 16, 2003 | 01:36 PM
jimswhite92's Avatar
jimswhite92
Mark,
If you don't get it resolved I will check out the wiring diagram tonight when I get home.
Jim
To Electrical problem - hatch open light
