This ought to settle the LT header issue
Here are my before and after dyno charts with a modded LT1 engine. The first dyno I had the LT4 Hot Cam Kit installed with ported heads, but still had the cast iron manifolds with a small cat-back exhaust. The curve is flat like an LT1 should be, and it doesn't begin to fall off till relatively high revs. But the torque and max power are disappointing.
Full size here: http://162.33.142.18/cars/DynoOne.jpg
Now for the after dyno results. The difference is TPIS long tubes with a full 3" custom exhaust, emissions legal with Random Tech bullet cats. My buttometer said the change was good, this confirms it.
Full size here: http://162.33.142.18/cars/DynoThree.jpg
I have never seen an LT1/4 dyno chart with a bump in the torque curve like this. I can feel the power come on when it hits this bump. Never mind the max rwhp being only 353, the operator cut it off at 5700 rpm because I haven't increased my rev limit yet.
50 ft lb of torque from LT headers, x-pipe and unrestricted 3" full exhaust. And it passes emissions testing with an early pass. I am more than pleased, I am ecstatic!!!
[Modified by 94lt1torchred, 8:11 PM 12/16/2003]
[Modified by 94lt1torchred, 8:14 PM 12/16/2003]
i hope to get 25-35 hp out of my TPiS long tube headers i need to install :) when i do the headers and afpr i'm gonna dyno tune so i can get a chip burned.
don't know where you dyno tune at but i know a shop local that does 100 bucks an hour dyno tuning.
94LT1', I will be happy with 1/2 the gains you recieved. Those #'s are incredible for an exhaust upgrade.
Incredible? More like "astounding"! I did more upgrades than that to my LT1 and don't have near the HP and torgue readings he got. I'd be interested in knowing what that rascal will do on the strip. That's where the "proof of the pudding" is really shown.
The Random Tech cats cost $320 for the pair. I got them from Thunder Racing at a better price than from TPIS.
I don't want to see much better than 12.5s this spring cause then I'll have to spend on gears. Is there any cure for this modding disease?
I am running much leaner than the other big HP cars at the dyno day. My car does not blow a mosquito killing cloud like the others do at revs. fdupny's Z06 is much richer than mine on his chart, and he was making us back away from that thing. But what a sweet sounding car he has with B&B pipes.
The question is, is it too lean for safety (probably not), and as you said am I giving up power without the tune? Probably am.
One other difference, I have hand ported heads and I requested a street setup. Vs. CNC heads from other sources. So my porting probably matches the Hotcam and LT1 intake better in this rev range than CNC heads would. The whole thing together works well.
[Modified by 94lt1torchred, 7:59 PM 12/17/2003]
It makes sense that you are leaner now on the top end than before. The headers help the scavenging affect and pull more gases from the cylinders leaning them a little.
