Battery draining
Old Dec 18, 2003 | 08:03 AM
Steve's98's Avatar
Steve's98
Default Battery draining
I have a 89 with a newer Delco battery. The car wont start after a week and a half to two weeks of sitting. I live in Chicago and it is cold here now, but I know that it should last longer then that. What is the best way to check for a short?
Thanks,
Steve
Old Dec 18, 2003 | 08:31 AM
jmrl98's Avatar
jmrl98
Default Re: Battery draining (Steve's89)
Don't count out the bad battery. I bought a delco from a recommended place, and it was bad. When I took it back a week & 1/2 later, the place had taken them out 'cause they weren't selling! I called Delco, they told me to take it to some other retailers for a new one. I got a delco from Murray's (don't know if you have those in Chi-town) and that was bad, according to their battery charger!! Went to Sears and got a diehard, no problems since. You should have a trickle charger on the battery - it will help. I don't really "store" my car - I start it every 2-3 weeks and take for a short drive, if the snow/salt allows. :seeya
Old Dec 18, 2003 | 10:39 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
take it out, get it checked.... :thumbs:
Old Dec 18, 2003 | 06:36 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: Battery draining (vinnies87)
:iagree:
Go from there.
tony
Old Dec 18, 2003 | 07:20 PM
Sam Lam's Avatar
Sam Lam
Steve: An easy check would be to make sure the battery is fully charged with engine off (voltage should be 12.5 to 13 volts). Disconnect the positive terminal and let her sit for a week. Reconnect the battery and see what happens. This will tell you if you have a bad battery or a "short" somewhere. I hope you do not have a short as this can be a "pesky" problem!
Old Dec 18, 2003 | 07:52 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
AC Delco batteries are notorious for having the terminals fall out. It's not always noticable, so you may get a short due to it's falling out(but not all the way). My car was on it's 3rd battery(in 5 years) because of this. I know this for several reasons. Reason 1, I saw a terminal from a previous battery in the bottom of the tray. Reason 2, I met the original owner and she told me that had happened.
Old Dec 18, 2003 | 10:39 PM
SPEED750's Avatar
SPEED750
Default Re: Battery draining (Mr Mojo)
Disconnect the negative side of the battery.Now take 12volt test light and connect it between the neg post and your battery cable.It should light up for 1/2 second while it powers up your computer/clock whatever.If it stays lit then you have a problem.Start pulling fuses untill the light goes out, then you know what circuit is pulling a drain. :chevy
Old Dec 19, 2003 | 08:08 PM
TheStef's Avatar
TheStef
Default Re: Battery draining (SPEED750)
I have an aftermarket alarm system... my battery also goes dead after about 1 week and half to two weeks of being parked "its parked for winter"
I figured it was just because of my aftermarket alarm system draining the battery.
Just trying to give you some ideas
Old Dec 21, 2003 | 12:37 AM
JAKE's Avatar
JAKE
Default Re: Battery draining (TheStef)
A malfunctioning digital dash will pull down an battery too.
Jake
Old Dec 22, 2003 | 08:34 PM
TheStef's Avatar
TheStef
Default Re: Battery draining (JAKE)
hmmmm I do have a number that is half broken on the digital dash :confused:
To Battery draining
