Wheel Hub Disassembly...
Old Dec 19, 2003 | 07:56 AM
easton2's Avatar
easton2
Navigator
Default Wheel Hub Disassembly...
Does anyone know how to disassemble the front wheel hub ??
I would like to change the bearings and detail the hub.
Is there a "special" tool, needed to assist in this task ??
Old Dec 19, 2003 | 08:29 AM
sraft's Avatar
sraft
Default Re: Wheel Hub Disassembly... (easton2)
The hub/bearings (both front and rear) are sealed assemblies that don't come apart. You can remove them from the car for cleaning/detailing, but they are not servicable - when they fail they are replaced.
Old Dec 19, 2003 | 09:36 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Wheel Hub Disassembly... (sraft)
:thumbs:
Old Dec 19, 2003 | 03:52 PM
easton2's Avatar
easton2
Navigator
sraft....thanks very much for the info.
I was "afraid" of this.
Any ideas on how to detail this unit ???
:leaving:
Old Dec 19, 2003 | 04:36 PM
Trog's Avatar
Trog
What do you mean by detail?? You can make it look pretty nice w/ just cleaning. Mine still had the stock grey paint & after I polished the surrounding alum. looked nice.
[Modified by Trog, 3:42 PM 12/19/2003]
Old Dec 19, 2003 | 06:54 PM
easton2's Avatar
easton2
Navigator
Default Re: Wheel Hub Disassembly... (Trog)
Trog...
the spindle looks great !!
I am doing the same except after polishing, I am going to Hard Clear Anodize all of the pieces. The wheel hub (that contains the wheel bearings) is the
piece in question, since it is made of steel. :D
Old Dec 19, 2003 | 07:10 PM
Goody's Avatar
Goody
I would clean it up real good so as to have all the rust removed, paint it a bit and then let it go at that. You don't see it and since it is a throw away part you don't want to go hog wild on it unless you own a trailer queen show car, then chrome it.
After you remove the wheel and brake stuff, there are four bolts holding it on. Undo the ABS sensor if equipped and the bracket that holds the ABS wire. It'll fall right out and then you can clean it all you like.
Old Dec 19, 2003 | 07:15 PM
Trog's Avatar
Trog
Default Re: Wheel Hub Disassembly... (Goody)
Thanks.
:iagree: with above though. You really can't see the steel part of the hub when the brake disk is installed.
Here is a shot of the rear & you can see the grey bearing/hub that I just cleaned & reinstalled.
Old Dec 19, 2003 | 08:35 PM
Upstate's Avatar
Upstate
From: [Quote=WOEII] Is dried brown doodie powders man! [/Quote]
You my friend, are the poster child for this disease called corvette :jester .
That looks very :cool: .
Old Dec 19, 2003 | 08:37 PM
atotalnincompoop's Avatar
atotalnincompoop
Thanks.
:cheers: :cheers: :cheers: :cheers:
Old Dec 19, 2003 | 08:40 PM
easton2's Avatar
easton2
Navigator
Goody & Trog,
Good Point !! I think I'll just sandblast and POR.
Should work out well.
What do you think ?? :confused:
To Wheel Hub Disassembly...
