Help! Stuck Emergency Brake Release
Old Dec 19, 2003 | 01:52 PM
WHRITZY's Avatar
WHRITZY
Default Help! Stuck Emergency Brake Release
Could use a litte advice - Parked my 90 on hilly driveway this morning. Had to pull up hard on emergency brake lever to engage her. Now, I can't get it disengaged - If I pull on handle any harder I"ll break housing off of door sill. Are there any tricks to pop her loose?
Any help in much appreciated! :flag
Old Dec 19, 2003 | 02:19 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: Help! Stuck Emergency Brake Release (Oldman)
I had the same thing happen to me once so dont feel bad! I went and got those angle neck screwdrivers and removed the cover. Had a look at the components and with some effort and needle nose pliers(sp?) I was able to work the lever and get the brake to release. It has worked fine ever since! I just remember to not pull up so hard! Hope this sort of helps. :)
Old Dec 19, 2003 | 02:49 PM
jiml94's Avatar
jiml94
Default Re: Help! Stuck Emergency Brake Release (WHRITZY)
If it is the same as my 94LT1, stick a thin blade screwdriver down into the slot where the handle goes in to the housing. There is a metal pawl that catches the mechanism. If you can stick the blade where the pawl sits, there will be a pop and the pawl will release the ratcheted brake mechanism.
[Modified by jiml94, 1:51 PM 12/19/2003]
Old Dec 19, 2003 | 05:18 PM
WHRITZY's Avatar
WHRITZY
Default Re: Help! Stuck Emergency Brake Release (jiml94)
Fellas, thanks for all the answers! I'll give it a whirl and let you know how it turned out.
Old Dec 20, 2003 | 01:21 AM
BAM92's Avatar
BAM92
Uh, if your still on that hill when you release that brake mechanism.........
To Help! Stuck Emergency Brake Release
