optispark help needed
Old Dec 21, 2003 | 09:17 AM
JAYK's Avatar
JAYK
Default optispark help needed
Hello,I am looking at changing over to the newer gen II style opti,I have a Lingenfelter 74219 cam at the moment for gen I opti what will I need to do to be able to use it with gen II opti and what else will I need to replace while I am in there.Thanks
Old Dec 21, 2003 | 09:51 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: optispark help needed (JAYK)
I used to have more links on the opti, but I can't find them, but here are a few that may or may not help. http://www.fierolt1.com/lt1_95_up_OptiReplace.htm
http://www.gmhightechperformance.com...htp_optispark/
http://para.noid.org/~muttvette/opti.html
Old Dec 21, 2003 | 10:34 AM
STL94LT1's Avatar
STL94LT1
The Gen II opti uses a longer dowel pin in the camshaft.
Old Dec 21, 2003 | 10:49 AM
bogus's Avatar
bogus
for the cost of a gen2 opti upgrade, I would consider some opti alternatives...
the LTCC is a good choice.
http://forums.corvetteforum.com/zerothread?id=709638
or this:
http://forums.corvetteforum.com/zerothread?id=706782
To optispark help needed
