ABS wheel sensor check
Alsp thinking about haveing the brakes lines flushed and beld somewhere. Anyone know of a service chain that will do that?
I bought one of those "one man brake bleeder" sets for like 5 bucks. I've heard that you can run into problems using those because if it's not held tight you can get air in there. To remedy that I used two men for my one man brake bleeder.
All the set is is a little plastic nozzle that goes into the bleeder screw. Attached to the nozzle is a tube that goes into a small airtight bottle.
Put the nozzle into the hole for the bleeder screw and loosen the screw. Have one person hold the nozzle tight so no air gets in, and they can monitor the bottle to let you know when to stop pumping because the bottle is full.
So while your friend is monitoring it, pump the brakes. It's absolutely vital that you don't let your master cylinder run dry, so make sure to keep some fluid in there. If it runs dry you'll get air in the lines. When your friend tells you the bottle is full, close the bleeder screw (so no air gets in the lines) and remove the nozzle. Empty the bottle and start over.
You'll know that you've finished that wheel when pure, clean brake fluid starts coming out into the tube. It'll be pretty obvious when contrasted against old dirty brake fluid in the clear tube. After you have clean brake fluid coming out at all four wheels, there's pretty much no way there can be any air in there unless you have a leak somewhere.
Also keep in mind that you'll want to do them in order of furthest to closest in relation to the ABS unit, not the master cylinder.
If for whatever reason you don't feel like doing it yourself, I'm sure any automotive shop would do it for you. Just call around for pricing.
Make sure they understand you want it fully bled with all brand new fluid in the reservoir as well. Sometimes they can do a half-butt job.
Them is some pulsation in the rotors, could that cause the light to be on? The pads and rotors look ok and when measured for thickness showed they could be machined.
It would probably be more cost efficient to have them check it out and fix the abs at the same time they do the brakes. Maybe doing the diagnoisis with the computer bot first.
Does that sound right?
Step one in most trouble shooting schemes is checking the resistance. You can pull the ABS sensor connection, place the multimeter in OHMS, connect the probes to each pin, take a reading. Recommend a good Fluke multimeter, take the plunge.
I would check the wheel bearing replacement. If the sensor is connected, there should be a boss for the sensor and the wheel bearing likely has the toothed wheel called the reluctor. Senors get dirty. Removing, checking, cleaning is usually the first step.
Does the light come on after startup and before moving the car? Or, does the light illuminate a few seconds after the car starts moving?
This system can be tough. Make darn sure the person working on this system is up to speed on Corvette ABS or you will be wasting your money and their time.
Do a search "ABS" and you should find some really good writeups.
Let us know.
dlmeyers 90 coupe zf6 3 speed shocks
