Clutch Replacement
Old Dec 22, 2003 | 03:37 AM
93Ruby's Avatar
93Ruby
Default Clutch Replacement
Getting ready to replace the clutch on my 93 and was wondering if there are better replacements than the GM one. Also need to know if there are any other items I should change other than the clutch disk, pressure plate, and release bearing? Any advice would be greatly appreciated. :flag
Old Dec 22, 2003 | 11:12 AM
bogus's Avatar
bogus
Default Re: Clutch Replacement (93Ruby)
flywheel. it cannot be resurfaced and is expensive.
how many miles?
do you have mods?
if stock, I would stick with stock.
Old Dec 22, 2003 | 11:53 AM
93Ruby's Avatar
93Ruby
Default Re: Clutch Replacement (bogus)
The fly wheel needs to be replaced??? The car has almost 90,000 miles on it. :flag
Old Dec 22, 2003 | 01:01 PM
bogus's Avatar
bogus
yup. you can try to reuse it... but it is not recommended.
the dual mass is a pain... it has 2 chunks of steel, joined by a rubber "spring". the rubber does not like getting contaminated by the lube used during cutting, then, there is a fitment issue from having a flywheel that is too thin.
some have tried it... but I am not convinced it will last.
To Clutch Replacement
