Remove Oxygen Sensor to Repaint Exhaust System
Old Dec 22, 2003 | 11:05 AM
CE King's Avatar
CE King
Default Remove Oxygen Sensor to Repaint Exhaust System
I am wanting to repaint the exhaust system, from the header to the tailpipe. I have a '96. What is the best way of removing the oxygen sensors in order to be able to drop the exhaust system. Would it be best to just disconnect the electrical leads at the sensors and leave the sensors in place. I am planning on removing the entire exhaust system and repainting it while it is off the corvette.
Old Dec 22, 2003 | 11:11 AM
bogus's Avatar
bogus
Default Re: Remove Oxygen Sensor to Repaint Exhaust System (CE King)
hm. repainting the most abused part of the car? gee...
however, disconnect them, and then unbolt them from the exhaust. I don't think paint will do them any good.
Old Dec 22, 2003 | 01:30 PM
C4Crazy787's Avatar
C4Crazy787
Default Re: Remove Oxygen Sensor to Repaint Exhaust System (bogus)
I would disconnect the wire and then tape them off, I would not risk pulling them, plus I think you need a special thread sealer?? :seeya
Old Dec 22, 2003 | 02:24 PM
NoWorries's Avatar
NoWorries
Painting the exhaust is going to be a WHOLE lotta work for absolutely no gain, in my opinion.
However, the easiest way, if it is possible, is to disconnect the wire at the quick disconnect. Unfortunately just about every quick-disconnect on any O2 sensor has melted shut.
Removal is easy, just use a 7/8s wrench(pretty standard size for O2 sensors), and tap it off, do not apply torque, or it is entirely possible to snap the sensor clean off.
Reinstallation requires an "O2 sensor safe anti-sieze", available for about a buck at any autoparts store.
:seeya
Old Dec 22, 2003 | 03:26 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: Remove Oxygen Sensor to Repaint Exhaust System (NoWorries)
What kind of paint are ya using? Why would you do this anyway?
just curious.... :confused:
Old Dec 22, 2003 | 04:03 PM
CE King's Avatar
CE King
I will be using Eastwoods High Temp paint. This is specifically designed for exhaust systems.
Old Dec 22, 2003 | 04:29 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Not to rain on your parade, but I agree with the others here. Doing what you're planning is going to take a whole heck of a lot of work. And over time, possibly a very short period of time, your paint is going to flake off and leave you wondering why you went through all the trouble, in the first place.
When I pulled the headers on my C3, I figured I'd dress them up with some high temp paint. So I blasted them and then hit them with the high temp paint. Of course, after painting, you need to cure the paint at a certain temperature for a given period of time. My engine was out, so I had to improvise. I took a MAP gas torch and directed it into each header for a period of time. And then the headers sat until I was ready to reinstall. I fully expected my paint job to fail quickly. Instead, it took roughly 1500 miles to fail. There's still some paint on the headers, but where it matters, right where you look into the engine bay, you can see the crappiness.
I would not waste my time to recreate this experience, even if my engine was back out of the car. I would however, consider a ceramic coating.
Old Dec 23, 2003 | 12:40 AM
C4Crazy787's Avatar
C4Crazy787
Default Re: Remove Oxygen Sensor to Repaint Exhaust System (joeveto)
I painted my exhaust from the cat's back 2 yr's ago and it's holding up good just snapped this pic about 2 hr's ago. I dropped the system and repainted the mufflers black and the pipes silver, just high temp paint from autozone. It's a little dirty right now but cleans up nice for shows and stuff.
I thought it was worth it, plus I replaced all the exhuast nuts and bolts with stainless steel ones while I had it off. :seeya
To Remove Oxygen Sensor to Repaint Exhaust System
