low coolant
Old Dec 22, 2003 | 12:21 PM
bulldogred's Avatar
bulldogred
Default low coolant
Hi Everyone.
I have a Blue 1989 and a Red 1974. The '89 has a problem that I can't seem to fix. The low coolant light comes on and off intermittently. Sometimes not for days. Sometimes it will come on (after reaching oper. temp.) and then go off. The coolant is full in the radiator and resevoir. I thought the radiator cap may be bad so I replaced it. I thought that was the fix as it didn't come on for days, but now it's back. Any suggestions are greatly appreciated.
Merry Christmas to all.
Old Dec 22, 2003 | 12:24 PM
HapAFcop's Avatar
HapAFcop
Default Re: low coolant (bulldogred)
Sounds like you might have air trapped in the system. Check out this post for instructions on how to "burp" the system.
http://forums.corvetteforum.com/zerothread?id=710223
Good luck & Merry Christmas
Old Dec 22, 2003 | 12:33 PM
bulldogred's Avatar
bulldogred
Default Re: low coolant (HapAFcop)
Thank you. I will try this.
Old Dec 22, 2003 | 12:52 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
May have to do it a couple of time,,, Took me 3 times till i finally got all the air out....
Old Dec 22, 2003 | 04:46 PM
HapAFcop's Avatar
HapAFcop
Default Re: low coolant (vinnies87)
:iagree: You may have to do it a couple of times to get all the air out. Let us know if this works for you.
Old Dec 23, 2003 | 09:37 AM
dwestsr's Avatar
dwestsr
When I replaced my Tstat (180) I drilled 4 1/16 holes around the perimeter of it. If I open my cooling system for any reason, It will purge by it'self but it does take a few heating and cooling cycles to do it. Until it does purge , I get intermittant low coolant light but no overheating. :cheers:
Old Dec 23, 2003 | 09:41 AM
bulldogred's Avatar
bulldogred
Default Re: low coolant (dwestsr)
Thanks for all the replies. I am going to try this over the Holidays.
Old Dec 31, 2003 | 11:47 AM
bulldogred's Avatar
bulldogred
Thanks for the information. I have not seen the light in days!
Old Dec 31, 2003 | 12:01 PM
vinnies87's Avatar
vinnies87
:cool:
To low coolant
