Can anyone identify these?
Old Dec 23, 2003 | 06:18 AM
C10 JDR's Avatar
C10 JDR
Default Can anyone identify these?
I have changed the chip in my ECU, (in dash passenger side), and I cant remember where these things fit - any ideas?
Thanks in advance.
[Modified by britvette, 12:27 PM 12/23/2003]
Old Dec 23, 2003 | 06:38 AM
nitrous1's Avatar
nitrous1
St. Jude Donor '06-'07-'08-'09
Default Re: Can anyone identify these? (britvette)
Those look like the clips on the sides of ECM wiring harness connectors. The ones on my 86 are very similar if not identical. My ECM has two connectors on it and each connector has two of those clips.
Old Dec 23, 2003 | 07:32 AM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Default Re: Can anyone identify these? (nitrous1)
:iagree:
Old Dec 23, 2003 | 07:37 AM
C10 JDR's Avatar
C10 JDR
Default Re: Can anyone identify these? (Coupe89)
That sounds highly likely, will check it out tonight - thanks friends.
:D
Old Dec 23, 2003 | 09:36 AM
brookman's Avatar
brookman
These are also on the digital gauge cluster. I am guessing they had a problem with pins backing out of the connectors and these stop that from happening.
Old Dec 23, 2003 | 10:42 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
:iagree: on my 87 also... go in to hold the harness to the ecm connector.. only fit one way... so should be easy... :thumbs:
Old Dec 23, 2003 | 10:57 AM
C-4 Cross Fire's Avatar
C-4 Cross Fire
Default Re: Can anyone identify these? (vinnies87)
Yup--everyone's right--they hold connectors together so they can't unplug on their own.
Good luck, bro!
Old Dec 23, 2003 | 12:47 PM
NoWorries's Avatar
NoWorries
They are extra. :seeya
I install all electrical components in my Vette without the annoying things and haven't had a problem yet. :seeya
Old Dec 23, 2003 | 01:27 PM
scorp508's Avatar
scorp508
Default Re: Can anyone identify these? (brookman)
:yesnod:
Old Dec 23, 2003 | 01:58 PM
Millican's Avatar
Millican
Default Re: Can anyone identify these? (scorp508)
Those are wire combs. They keep pressure on the connector contacts to keep them firmly seated in the connector.
Old Dec 23, 2003 | 05:45 PM
redfast's Avatar
redfast
Default Re: Can anyone identify these? (Millican)
Iv'e seeen these before :eek: :eek: just about every eletrical connection in newer cars use those type of connectors. Those look like they go to the digital dash or the computer. :flag
Old Dec 24, 2003 | 07:42 PM
C10 JDR's Avatar
C10 JDR
Default Re: Can anyone identify these? (redfast)
These particular ones are definitely computer - I haven't been near the dash. Thanks for your help, and oh - MERRY XMAS.
:party:
To Can anyone identify these?
