looking for JEB !!!
Old Dec 23, 2003 | 12:53 PM
mike 1985's Avatar
mike 1985
Default looking for JEB !!!
I once saw a pic of an intake track you built, ( i believe it was hand crafted alum and picked air up from the front and went to a aftermarket throttle body)do you still have that pic and if you do could you post it or send it to me please ?
Secondly have you picked your D-36 project car yet ?
[Modified by mike 1985, 5:54 PM 12/23/2003]
Old Dec 23, 2003 | 01:24 PM
ANTI VENOM's Avatar
ANTI VENOM
Default Re: looking for JEB !!! (mike 1985)
He sent those pics to me. If he doesn't respond, I will send them to you.
Old Dec 23, 2003 | 01:28 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: looking for JEB !!! (ANTI VENOM)
Not Jeb, But I ran the intake for Jeb during the tests. VERY good results I might add. As good as the SR, with too little gear, installed the night before, and no tuning. It ran within a few hundreds of my best time with the SR. Lotsa potential.
We (Corky and I ) are both building 434, 650+ HP, and will be running this intake. :cheers:
here is the link to one of the posts with the intake pictures. This was just a prototype. The next generation will be much prettier. :)
http://forums.corvetteforum.com/zero...184#1545677184
Old Dec 23, 2003 | 01:54 PM
mike 1985's Avatar
mike 1985
Default Re: looking for JEB !!! (ski_dwn_it)
thanks guys.
Antivenom if he doesn't answer by tomorrow , please send them to me.
Ski-dwn -it. I'm not so interested in the intake as the duct work he made to go to it when he ran it with a regular holley type induction , as i'm running a carb now and need to find a way to get ample intake air to the set up.
I followed your testing and learned from it. Good luck with your 434? Will either one of them be 18 degree headed motors ?
Old Dec 23, 2003 | 02:16 PM
jburnett's Avatar
jburnett
I'm here... Are you talking about the airbox I built for the 4v throttle body when I ran it?? It was .060" aluminum fabbed up and fed by two K&N cone filters up front. It worked nicely but was pretty restrictive on my nearly 570 hp 396. I'll try and find the pics or AntiVenom can post them on here...I believe Jesse also has some pics of the setup.
-Jeb
Old Dec 23, 2003 | 02:40 PM
mike 1985's Avatar
mike 1985
Default Re: looking for JEB !!! (jburnett)
Yes sir, that's the one. Do you remember roughly how tall it is for hood clearance above the radiator ?
I only need to feed 400 HP naturally aspirated and then i'm spraying 250 to it.
My only other option would be a 2.5" air cleaner, due to hood clearance.
thanks
Mike
Old Dec 24, 2003 | 12:04 PM
jburnett's Avatar
jburnett
It's about 1.9" tall if I recall correctly... I'm not using it and would sell it IF it would fit your needs but I don't know if it will... I designed and built the thing around my car (1990) and my wife has an '85 like yours; they have a straight up and down radiator and the '90 is slanted. That may make a difference. I'll send you some pics in a little while.
-Jeb
Old Dec 26, 2003 | 08:17 AM
mike 1985's Avatar
mike 1985
thanks. I'll measure to see how much room i have for clearance above my radiator.
Mike
To looking for JEB !!!
