Hi, all. Newbie here. Bud Terry from South Jersey. My dash is acting up which I hear is a common ailment. Before I do a nearly $300 exchange with instrumentclusters.com, any tips on R&R or diagnostic info?
My dash will sometimes work fine other times it will go nuts. Sometimes flickering. Sometimes appearing to try to run a diagnostics by cycling through all the LED segments in a clockwise pattern. Sometimes appearing to try to alternate between eng/met (hitting the switch has no effect). This behavior does NOT seem to be caused by vibration, jarring, or temperature. it's totally random.
