6-SPEED T56 MANUAL TRANS
For one I consider it more 'bulletproof' than the ZF because you hear less about its synchronizers failing (I keep hearing the ZF is bulletproof except for the synchronizers. Well, if I still have to pay $x000.00 to get the synchronizers fixed, it is not 'bulletproof' to me).
Im kinda salty about the ZF because I sometimes get higher RPM gear clash (grind when going 1-2 at say 6000 RPM). I am told this is because my synchronizers might be failing. I just replaced the clutch hydraulics and hope this will cure this and that I didnt do too much damage to it already.
Some people say, oh, it sounds like your ZF was 'abused'. How exactly do you 'abuse' a transmission, especially one that is 'bulletproof'. Do you think the previous owner went out and said 'yeehaw, lets abuse the tranny tonight by not pushing the clutch pedal in all the way while shifting, shifting into reverse while going forward, etc)'....It just seems unlikely.
Also, The ZF has a lot of useless weight. I believe its at least 30 pounds heavier than the T56.
Id love to see a swap.
I'm a newbie at this so I should take the path of least resistance. Maybe the swap of the tranny is the way to go.
I have seen T56s blow up after 20k miles... now, most of those were a 1/4 mile at a time, but the end result is the same.
Sure, the ZF may have weak syncros, but I don't agree they are THAT weak. I am more concerned with the T56 throwing bearings than some slow dogs on ZF6.
T56s have a tendency to wear out syncros by just driving them... in 100k miles they eat themselves up. (see the story in this months issue of Corvette Enthusiast, very revealing).
a ZF will last 200k miles without any major problems (used exclusivly on the street).
Sure, the ZF is heavier, won't fight you there, but I have driven both, and I much prefer the feel of the ZF over the T56 (Fbody's).
Also, you can get a ZF built to a standard of perfection that will make it never blow.... it ain't cheap, but I believe in doing something once, and being done.
remember, there are guys out there who are running 800hp SBC's with ZFs, basically stock, and are not blowing up... try that with a stock T56.
Nothing is perfect, it's just what is more perfect than the other.
I think the biggest problem with the ZF is a lack of maintenance. If the owners changed the oil in the ZF on a regular basis, the syncros will last that much longer.
with the fitment issues of the T56, I am going to stick with the ZF...
Unless he is planning to make an assanine amount of power, either tranny is going to work fine for him.
http://home.earthlink.net/~rontyler/t56.html
I'm waiting on information on the Richmond swap. I'm so new I don't even know what a Richmond is. Anybody care to illuminate me on the subject?
Again thanks for letting me pick your brains for this. You've all been invaluable.
I don't think I know a single person with a ZF6 that has gone this long without SOMETHING happening. :confused:
racing hurts components. I have never heard of a ZF blowing up... just wearing out...
mine has 121k and has no problems...
