Once after each startup the ECM advances timing till it gets a knock count, to test the knock sensor. This is one reason that the knock counts gradually increase.
In addition knock counts can be caused by a bad knock sensor, by metal rattling near or against the block , by low octane fuel and by too much base timing.
If possible monitor knock counts while driving to see if they increase after a WOT burst for example.
