Sunvisor removal question
Old Dec 30, 2003 | 03:32 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Sunvisor removal question (LoneStarSoldier)
I had to bang on the center of my retraine a little so it would hold well enough when I pushed it down over the spring. I then put a small nut over it just so it wouldn't come off in case the little fingers didn't hold.
Old Dec 31, 2003 | 01:52 PM
C-4 Cross Fire's Avatar
C-4 Cross Fire
Default Re: Sunvisor removal question (65Z01)
OK--ready for this--get a 1/2" socket and set it over top of the metal retaining washer/nut thing with the open end of the socket touching the washer/nut thing. Hold the socket against the washer/nut thing and whack the socket with a hammer and the washer/nut thing will be off of the shaft ans just sitting there under the socket with the spring still underneath. You put it back on the same way!
No kidding. :eek: :cool:
