?'s on engine block
Old Dec 26, 2003 | 05:55 PM
vetteguy216's Avatar
vetteguy216
Default ?'s on engine block
Is this block in good shape? The block is on ebay the Item # is 2449782053
The one of the main caps is cracked can it be repaired or replaced. Also the block has been repaired before it shows it in the second picture. Will it be a problem?
[Modified by vetteguy216, 5:56 PM 12/26/2003]
Old Dec 26, 2003 | 06:20 PM
scorp508's Avatar
scorp508
Default Re: ?'s on engine block (vetteguy216)
Well its got a 4.255" bore which is 0.005" over normal. From what I know you can usually take a 454 block to 4.31" max overbore so it should clean up nicely. The thing that worries me is why is a main cap busted? Sure replacing it is easy, but it takes a lot to do that in the first place. What sort of hard life may it of had? Is it close? I would request magnafluxing the block before purchase. Then again its only $49.99.
Old Dec 26, 2003 | 06:22 PM
scorp508's Avatar
scorp508
Default Re: ?'s on engine block (scorp508)
I noticed that wierdness between 2&4, I'd like to know what that is too. I can't see a sleeve from the pics.
Mortec reports that block as being: 3999289....454.......72-79...2 or 4 bolt, some "CE" replacement blocks had four bolt main caps
Old Dec 26, 2003 | 06:49 PM
vetteguy216
I cant imagine what happened in order for them to have to repair that?
[Modified by vetteguy216, 7:25 PM 12/26/2003]
Old Dec 26, 2003 | 07:08 PM
CFI-EFI's Avatar
CFI-EFI
To me, the answer is is in the explaination.
RACE ON!!!
To ?'s on engine block
